I'm Running AutoCAD 2016 (with mechanical Desktop as if that matters) and the Annotative Object Scale option is missing when I select an annotative object and right click.
SOMEBODY PLEASE HELP!:x
As suggested in the other thread, read post #10 of that thread. There you will see that the item does not show up in the right click menu when using mechanical, so it does matter. You can use the object properties palette and click on the Annotative scale item to get it to expand, then click what you need there.
Note that if multiple objects are selected, and they are of mixed types, Annotative Scale will not show up in the properties palette either.
Dana nailed it. :beer:
Personally I am a big fan of Quick Properties, which you could select at the bottom of the right click shortcut menu. :|
The Annotative Object Scale may not display by default on that, not sure. If you right click on the left side of the QP display, you can CUSTOMIZE it, to display whatever you want. :|
