hi,
How i can publish in model having lot of drawing as shown in image
Just to confirm. You want to print all of those separately from model space (no layouts being used). Correct?
I want to print all of those separately from model space.
shuhaib
If you have formats of different sizes - attach an example .dwg
shuhaib
Did you look at the image the OP attached? All the model space drawings appear to be one size so it stands to reason that when they are printed it will be to one size does it not?
There was another post request like this where there was different sheet sizes and orientation as well, it could still be done but means in the code would have to add a number of conditions for each title block size & orientation.
