Remove [####.##.##] from a string
eg.
"[2017.03.06][2016.12.10]Blueprint.dwg"
When removed
"Blueprint.dwg"
normally we would use wcmatch,
alternatively i use list method bcos i see the brackets [##]
(setq str "[2017.03.06][2016.12.10]blueprint.dwg")
(strcat	(vl-string-right-trim
  (apply 'strcat
	 (mapcar ''((x) (strcat (vl-princ-to-string x) " "))
		 (vl-remove-if 'vl-consp (read (strcat "(" (vl-string-translate "[]" "()" str) ")")))
".dwg"
Edited by hanhphuc
accept string with space , vl-string-right-trim
Disadvantage the string must be no spacing, example "blue_print.dwg"
"blue print.dwg" failed
(strcat
(vl-princ-to-string
 (car
   (vl-remove-if
     'vl-consp
     (read
(strcat "(" (vl-string-translate "[]" "()" str ) ")")
 ) ".dwg")
Hi hanhphuc,
Thank you so much ! :)
I 'd like to see use wcmatch method.:D
Using wcmatch :
; _$ (foo "[2017.03.06][2016.12.10]Blueprint.dwg") -> "Blueprint.dwg"
; _$ (foo "[2017.03.06][2016.12.10]This is a test.dwg") -> "This is a test.dwg"
(defun foo ( s )
 (cond
   ( (wcmatch s  "`[####`.##`.##`]`[####`.##`.##`]*`.dwg")
     (substr s 25)
Using wcmatch :
(defun foo ( s )
 (cond
     (substr s 25)
Sorry , [####.##.##] maybe is not Two, maybe is one or Three.
Another, using Regular Expressions:
(defun foo ( str / rgx )
   (if (setq rgx (vlax-get-or-create-object "vbscript.regexp"))
           (vlax-put-property rgx 'global actrue)
           (vlax-put-property rgx 'pattern "\\[\\d{4}\\.\\d{2}\\.\\d{2}\\]")
           (setq str (vlax-invoke rgx 'replace str ""))
           (vlax-release-object rgx)
           str
_$ (foo "[2017.03.06]Blueprint.dwg")
"Blueprint.dwg"
"Blueprint.dwg"
_$ (foo "[2017.03.06][2016.12.10][2016.12.10]Blueprint.dwg")
"Blueprint.dwg"
Ah, now I understood the task! Here:
; _$ (foo "[2013.12.10]Blueprint.dwg") -> "Blueprint.dwg"
; _$ (foo "[2015.08.10][2016.12.10]This is a test.dwg") -> "This is a test.dwg"
; _$ (foo "[2012.02.13][1991.08.10][2016.12.10]And Another test.dwg") -> "And Another test.dwg"
(defun foo ( s )
 (cond
   ( (wcmatch s  "`[####`.##`.##`]*`.dwg")
     (while (wcmatch s  "`[####`.##`.##`]*`.dwg")
       (setq s (substr s 13))
Lee your code blews my mind!
Thanks Grrr :thumbsup:
Note that your code could become:
(defun foo ( s )
   s
This way, the function will return the original string rather than nil if the pattern is not found.
Thanks Lee, sometimes I overthink the code and can't see easily that it could be shortened. :)
Lee , hanhphuc, Grrr, Thank you very much! 8)
