rlcad Posted March 21, 2017 Posted March 21, 2017 When I try to insert text in a Table's cell, sometimes I need the second line to be centered; but the Alignment buttons (Center, Left, Right, Justify etc) are inactive. What is the problem? Thanks. Quote
SunnyTurtle Posted March 21, 2017 Posted March 21, 2017 Text alignment is not a option for a table cell. But you can change it via Justification while entering text. or by the "Cell Styles" Tab in the Table Cell menu or by the properties window with a cell selected. Tables are a little bit tricky to get a hang of at first but keep persevering Quote
rlcad Posted March 21, 2017 Author Posted March 21, 2017 Is the cell format locked? No, it states "Unlocked". Quote
rlcad Posted March 21, 2017 Author Posted March 21, 2017 Text alignment is not a option for a table cell.But you can change it via Justification while entering text. or by the "Cell Styles" Tab in the Table Cell menu or by the properties window with a cell selected. I've tried the solutions. Justification moves the whole text. My cell has two lines: one that has to be justified left, and the 2nd, that has to be centered. Justification moves both of them to the center. Also, I can't even press Enter to go to the next line; or Tab. Quote
SunnyTurtle Posted March 21, 2017 Posted March 21, 2017 (edited) I've tried the solutions. Justification moves the whole text. My cell has two lines: one that has to be justified left, and the 2nd, that has to be centered. I see i cannot see a way to do that ether. I think the only way you can get around this is to create 2 cells and remove the border between them. (not perfect but with a bit of fiddling you can make it look as if you had 1 cell.) Also, I can't even press Enter to go to the next line; or Tab. In tables Enter is used to go to next row Tab is used to go to next column To go to next line you need Alt+Enter Edited March 21, 2017 by SunnyTurtle Addition Quote
