pawcyk Posted March 30, 2017 Posted March 30, 2017 Hello. Using marko_ribar lisp from: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/to-get-intersection-between-a-line-and-a-3dface/td-p/2745633/page/3 I made my version which inserts a point at the intersection of a vertical line with 3dface. I have many 3dFaces which looks like triangles. I make them using lisp: http://paulbourke.net/papers/triangulate/Triangulator.LSP My lisp sometimes works, and sometimes it print an error. Thank you for any help ;_ilt = intersection line and 3dface ;by marko_ribar ;link: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/to-get-intersection-between-a-line-and-a-3dface/td-p/2745633/page/3 ; (defun _ilt ( p1 p2 t1 t2 t3 / v^v unit Coplanar-p ptinsidetriangle-p ptontriangle-p ptonline-p _ilp nor o ) (defun v^v ( u v ) (list (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u))) (- (* (car v) (caddr u)) (* (car u) (caddr v))) (- (* (car u) (cadr v)) (* (car v) (cadr u))) ) ) (defun unit ( v ) (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v) ) (defun Coplanar-p ( p1 p2 p3 p4 ) ( (lambda ( n1 n2 ) (equal (v^v n1 n2) '(0.0 0.0 0.0) 1e- ) (v^v (mapcar '- p1 p2) (mapcar '- p1 p3)) (v^v (mapcar '- p1 p2) (mapcar '- p1 p4)) ) ) (defun ptinsidetriangle-p ( pt p1 p2 p3 ) (if (and (Coplanar-p pt p1 p2 p3) (not (or (inters pt p1 p2 p3) (inters pt p2 p1 p3) (inters pt p3 p1 p2) ) ) (not (or (> (+ (distance pt p1) (distance pt p2)) (+ (distance p3 p1) (distance p3 p2))) (> (+ (distance pt p2) (distance pt p3)) (+ (distance p1 p2) (distance p1 p3))) (> (+ (distance pt p3) (distance pt p1)) (+ (distance p2 p3) (distance p2 p1))) ) ) ) T nil ) ) (defun ptontriangle-p ( pt p1 p2 p3 ) (if (or (equal (distance p1 p2) (+ (distance pt p1) (distance pt p2)) 1e-7) (equal (distance p2 p3) (+ (distance pt p2) (distance pt p3)) 1e-7) (equal (distance p1 p3) (+ (distance pt p1) (distance pt p3)) 1e-7) ) T nil ) ) (defun ptonline-p ( pt p1 p2 ) (equal (distance p1 p2) (+ (distance pt p1) (distance pt p2)) 1e-7) ) (defun _ilp ( p1 p2 o nor / p1p p2p op tp pp p ) (if (not (equal (v^v nor (unit (mapcar '- p2 p1))) '(0.0 0.0 0.0) 1e-7)) (progn (setq p1p (trans p1 0 (v^v nor (unit (mapcar '- p2 p1)))) p2p (trans p2 0 (v^v nor (unit (mapcar '- p2 p1)))) op (trans o 0 (v^v nor (unit (mapcar '- p2 p1)))) op (list (car op) (cadr op) (caddr p1p)) tp (polar op (+ (* 0.5 pi) (angle '(0.0 0.0 0.0) (trans nor 0 (v^v nor (unit (mapcar '- p2 p1)))))) 1.0) ) (if (inters p1p p2p op tp nil) (progn (setq p (trans (inters p1p p2p op tp nil) (v^v nor (unit (mapcar '- p2 p1))) 0)) p ) nil ) ) (progn (setq pp (list (car (trans p1 0 nor)) (cadr (trans p1 0 nor)) (caddr (trans o 0 nor)))) (setq p (trans pp nor 0)) p ) ) ) (setq nor (unit (v^v (mapcar '- t3 t1) (mapcar '- t2 t1)))) (setq o t1) (if (_ilp p1 p2 o nor) (if (and (or (ptinsidetriangle-p (_ilp p1 p2 o nor) t1 t2 t3) (ptontriangle-p (_ilp p1 p2 o nor) t1 t2 t3) ) (ptonline-p (_ilp p1 p2 o nor) p1 p2) ) (_ilp p1 p2 o nor) nil ) nil ) ) ;; ;;BECAUSE THE 3DFACE HAVE 4 VERTICES (2 the same) WE HAVE TO REMOVE DUPLICATED COMPONENTS ;; ;; Unique - Lee Mac ;; Returns a list with duplicate elements removed. (defun remove_doubles (lst /) (vl-load-com) (if lst (cons (car lst) (remove_doubles (vl-remove (car lst) lst))))) ;; ;;Main program (defun c:bum () (print "pick 3dFace") (setq ssSelections (ssget)) (setq Point (getpoint "\nPICK A POINT")) (setq Point2 (list (nth 0 Point) ; Point i Point2 = line of 500 length (Line that crosses 3dface) (nth 1 Point) 500)) (repeat (setq intCount (sslength ssSelections)) (setq intCount (1- intCount) entSelection (ssname ssSelections intCount) lstEntity (entget entSelection)) ;3DFACE vertices (setq P10 (list (nth 1 (assoc 10 lstEntity)) (nth 2 (assoc 10 lstEntity)) (nth 3 (assoc 10 lstEntity)) ) P11 (list (nth 1 (assoc 11 lstEntity)) (nth 2 (assoc 11 lstEntity)) (nth 3 (assoc 11 lstEntity)) ) P12 (list (nth 1 (assoc 12 lstEntity)) (nth 2 (assoc 12 lstEntity)) (nth 3 (assoc 12 lstEntity)) ) P13 (list (nth 1 (assoc 13 lstEntity)) (nth 2 (assoc 13 lstEntity)) (nth 3 (assoc 13 lstEntity)) )) ;List of vertices with one (duplicate) deleted (setq ListVtx (remove_doubles (list P10 P11 P12 P13) )) ;Others 3 vertices (setq P100 (nth 0 ListVtx) P101 (nth 1 ListVtx) P102 (nth 2 ListVtx)) ;Making 3dPoint (entmake (list '(0 . "POINT") (cons 10 (_ilt Point Point2 P100 P101 P102)) )) );end repeat );end bum Quote
David Bethel Posted March 30, 2017 Posted March 30, 2017 I'be had luck with this type of testing before : ; 3 Points To 210 Extrusion Direction (LeeMac) (defun normal ( p1 p2 p3 ) (defun vxs ( v s ) (mapcar '(lambda ( n ) (* n s)) v)) (defun nrm ( v ) (sqrt (apply '+ (mapcar '(lambda ( n ) (* n n)) v)))) (defun one ( v ) (vxs v (/ 1.0 (nrm v)))) (defun vcv ( u v ) (list (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u))) (- (* (car v) (caddr u)) (* (car u) (caddr v))) (- (* (car u) (cadr v)) (* (car v) (cadr u))))) (one (vcv (mapcar '- p3 p2) (mapcar '- p3 p1)))) (defun c:test (/ p10 p11 f10 f11 f12 ucs pt1 pt2) (setq ld (entget line_ename) p10 (cdr (assoc 10 ld)) p11 (cdr (assoc 11 ld))) (setq fd (entget face_ename) p10 (cdr (assoc 10 ld)) p11 (cdr (assoc 11 ld)) p12 (cdr (assoc 12 ld))) (setq ucs (normal f10 f11 f12) pt1 (trans p10 0 ucs) pt2 (trans p11 0 ucs)) (if (setq ip (inters pt1 pt2 (list (car pt1) (cadr pt1) 0) (list (car pt2) (cadr pt2) 0) nil)) (prin1 ip) (alert "Line Does Not Intersect This Plane")) (prin1)) Assumes 3dface 12 & 13 are equal If the line is parallel to the ucs plane, it will never intersect ( probably your errors come from this ) Basically finding the ( inters ) of 2 lines translated to the ucs of 3 face points Normally I would then translate the ip to WCS. HTH -David Quote
pawcyk Posted March 31, 2017 Author Posted March 31, 2017 Thank you for your answer. I think in my code sometimes function _ilt print nil so it cant put a point. Quote
lrm Posted March 31, 2017 Posted March 31, 2017 I thought I would share this code I wrote to determine the intersection of any line (defined by 2 points) with the plane defined by a 3D Face. It does check if the line is parallel to the plane but not if the point is inside the bounds of the face. (defun c:FaceIntr (/) ; finds the point of intersection of a line defined by two points and a plane defined by ; a 3DFace ; L. Minardi 3/28/2017 (princ "\nPlease select 3DFACE and press ENTER.") (setq ss (ssget) ; get data for 3Dface en (ssname ss 0) edata (entget en) ) (setq p1 (getpoint "\nLine Start:") ; get two line points p2 (getpoint p1 "\nLine End") p1p2 (mapcar '- p2 p1) ; vector from p1 to p2 ) (setq fp1 (cdr (assoc 10 edata)) ;three corners of the 3DFACE fp2 (cdr (assoc 11 edata)) fp3 (cdr (assoc 12 edata)) ) (setq N (cross fp12 fp23)) ; normal to face (setq fp1p1 (mapcar '- p1 fp1) ; vector from face to line p1p2 (mapcar '- p2 p1) ; vector paralled to line ) ; determine if line is parallel to plane (setq Nxp1p2 (cross N p1p2)) ; N cross p1p2 (setq Ntp1p2 (* (distance '(0 0 0) N) (distance '(0 0 0) p1p2))) ; magnitude N times magnitude p1p2 (setq sinang (/ (distance '(0 0 0) Nxp1p2) Ntp1p2) ; sine angle between normal and line p1p2 ) (if (equal sinang 1.0 0.0001) (princ "\nNo intersection, the line is parallel to the face.") (progn (setq tk (- (/ (dot N fp1p1) (dot N p1p2))) ; value of parameter t at intersection ) ; intersection point of line and face using parametric definition of a line (setq PInt (mapcar '+ p1 (mapcar '* (mapcar '- p2 p1) (list tk tk tk)) ) ) (command "point" Pint) (command "line" p2 Pint "") (setq s (distance p2 Pint)) (princ "\n The intersection point is located at: ") (princ Pint) (princ "\nThe distance from line end point to the intersection is: " ) (princ s) ) ) ; end if (princ) ) ;end Face-Intr ;;; Compute the cross product of 2 vectors (defun cross (a b / crs) (setq crs (list (- (* (nth 1 a) (nth 2 b)) (* (nth 1 b) (nth 2 a)) ) (- (* (nth 0 b) (nth 2 a)) (* (nth 0 a) (nth 2 b)) ) (- (* (nth 0 a) (nth 1 b)) (* (nth 0 b) (nth 1 a)) ) ) ;end list ) ;end setq c ) ;end cross ;;; Compute the dot product of 2 vectors a and b (defun dot (a b / dd) (setq dd (mapcar '* a b)) (setq dd (+ (nth 0 dd) (nth 1 dd) (nth 2 dd))) ) ;end of dot Quote
