dgp123 Posted April 4, 2017 Posted April 4, 2017 step : 1 In Command line select similar enter, select multi object step : 2 In Command line MATCH PROPERTIES enter, already selected object are deselected. PROBLEM: MATCH PROPERTIES is not working for already selected object. Guide me...... Thank you.... Quote
ReMark Posted April 4, 2017 Posted April 4, 2017 My guess is you might have missed this..... Command: MATCHPROP Only one entity can be selected as source object. Quote
ReMark Posted April 4, 2017 Posted April 4, 2017 This is my problem The sentence in italics is the response one gets from AutoCAD if they pay attention to the command line. Your problem is that by using SELECTSIMILAR first you are picking more than ONE object. Understand? Quote
dgp123 Posted April 4, 2017 Author Posted April 4, 2017 Bro which means match properties is for only one entity is it.... Quote
ReMark Posted April 4, 2017 Posted April 4, 2017 Yo bro....that's the whole point of what AutoCAD is telling you. Test and read the command line. If you aren't seeing the message then hit the F2 key for the text screen. If you use SELECTSIMILAR then change properties via the Properties palette. That should work on anything that isn't a block. Quote
