zionshea Posted April 8, 2017 Posted April 8, 2017 Hello all, I am trying Autocad 2016 and looks like the setting for rendering is not easy as it was in 2015. Currently I have a problem with the shadow is rendered to dark. Generally I would like to have some basic setting to get a reasonable rendering in daylight. Quote
zionshea Posted April 9, 2017 Author Posted April 9, 2017 In the Render Preset Manager screen, the Render accuracy can be set to Low, Draft or High, When I set it to Draft or High the shadows are not dark anymore BUT the walls are too bright. When I change the Exposure in the Render Environment & Exposure to 11, then the walls are less bright but the glass looks milky. Then I change the White Balance and if it is 11K then the whole picture is blue like the image that I put in the background... and if I set it to 6K the glasses are milky again. Is there a basic setting to render like simple life view? (I had this for 2015) Thanks. Quote
zionshea Posted April 10, 2017 Author Posted April 10, 2017 When rendering, windows glasses are dark or milky - even with almost 100% material transparency, the glass is not transparent. Same drowing with Autocad 2015 was OK. Thanks Quote
zionshea Posted April 10, 2017 Author Posted April 10, 2017 set Exposure in the Render Environment & Exposure to 13 and the White Balance to 5000 and now the image is reasonable. (walls are not completely white-bright and the shadows are not dark). still,I have a problem with the windows that are not transparent. Quote
