thanhdattdk Posted April 11, 2017 Posted April 11, 2017 hello everbody, i want to Define coordinates point by code lisp but error (lselsetp or lentityp). I try to it but fail. hopy everboy help me.Thank everybody read my Thread ;============================================================================================= (defun LM:IntersectionsinSet ( ss / a b i j l ) (setq i (sslength ss)) (while (not (minusp (setq j (1- i) i (1- i)))) (setq a (vlax-ename->vla-object (ssname ss i))) (while (not (minusp (setq j (1- j)))) (setq b (vlax-ename->vla-object (ssname ss j)) l (cons (LM:GroupByNum (vlax-invoke a 'IntersectWith b acExtendNone) 3) l) ) ) ) (apply 'append l) ) (defun LM:GroupByNum ( l n / r) (if l (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (LM:GroupByNum l n) ) ) ) ;============================================================================================= (defun c:td (/ qa i) (command "_.STYLE" "VNI" "VN_VNI.SHX" "0.0" "1" "0" "" "" "") (setq qa (ssget)) (setq qa1 (ssget)) (setq k 0) (while (setq e (ssname qa1 k)) (setq qa (ssadd e qa)) (setq k (1+ k)) ) [b][u](setq lst (LM:IntersectionsinSet qa)) (foreach item lst (setq laynd (entget item)) (setq ndd (cdr (assoc 10 laynd))) (setq XCOC (car ndd)) (command "_.TEXT" "S" "VNI" "MR" item "1.8" "90" (rtos XCOC 2 0)) )[/u][/b] (princ)) Quote
Roy_043 Posted April 11, 2017 Posted April 11, 2017 Change: (foreach item lst (setq laynd (entget item)) (setq ndd (cdr (assoc 10 laynd))) (setq XCOC (car ndd)) To: (foreach item lst (setq XCOC (car item)) Quote
