In 2013 there is a right click shortcut menu in which i can hide selected solids, but in ver 2006 i don't find the command.
I do not believe that option was available back then.
Autocad 3D got a complete overhaul in 2007 and that's when most of the commands that you're used to working with in 2013 started. So, if you're using 2006, I'm afraid you're probably out of luck.
