eyal Posted April 18, 2017 Posted April 18, 2017 Hi Everyone, Can someone help me with lisp that turns lines to a construction lines? The lisp should ask for lines or polylines and it will turn the line to a construction line , even if I click a line on a rectangle ,it will change it to a construction line. Thank you. Quote
ReMark Posted April 18, 2017 Posted April 18, 2017 Is that something that can be done manually like changing a line to a polyline via the PEdit command? Quote
eyal Posted April 18, 2017 Author Posted April 18, 2017 Is that something that can be done manually like changing a line to a polyline via the PEdit command? No, I don't think so. I want with only one click to click on a line or rectangle line or any polyline straight line , and it change it to a construction line , with no layer change. of course with the same rotation (aligned) Quote
ReMark Posted April 18, 2017 Posted April 18, 2017 You may be in luck. Check out this thread regarding converting lines to xlines. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/constructing-infinite-lines-by-selecting-lines/td-p/4362861?nobounce Quote
