guitarguy1685 Posted April 24, 2017 Share Posted April 24, 2017 I would like to check if a Drive exists on a computer. I'm writing a lisp that will setup all support paths automatically. The user will be prompted as to whether they want the support paths pointing to their Local "C" drive or pointing to the server. if they want it to point to their local, I want to run a check to see if the following path exists "C:\CompanyCAD". If they want to point to the server I need to check if they have this drive mapped out "L:\Engineering\CompanyCAD I can still set the paths without them having access to either drive, I just want to send a warning if they don't. If your wondering why some people need local access. Some work offsite and load our CAD library on their local and work that way because running AutoCAD with VPN kind of sucks. Not sure if that's ACAD's problem or their ISP. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 24, 2017 Share Posted April 24, 2017 The following function will return a list of the drive letters in use: ;; Drive Letters - Lee Mac ;; Returns a list of drive letters currently in use (defun LM:driveletters ( / fso rtn ) (if (setq fso (vlax-create-object "scripting.filesystemobject")) (progn (vl-catch-all-apply '(lambda ( ) (vlax-for obj (vlax-get fso 'drives) (setq rtn (cons (vlax-get obj 'driveletter) rtn)) ) ) ) (vlax-release-object fso) (vl-sort rtn '<) ) ) ) Also posted here: https://www.theswamp.org/index.php?topic=47396.msg524127#msg524127 Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 24, 2017 Share Posted April 24, 2017 Alternative, assuming A: ; List all available disks (A: to Z:). (defun KGA_File_DiskList () (vl-remove-if-not 'vl-file-directory-p '("A:" "B:" "C:" "D:" "E:" "F:" "G:" "H:" "I:" "J:" "K:" "L:" "M:" "N:" "O:" "P:" "Q:" "R:" "S:" "T:" "U:" "V:" "W:" "X:" "Y:" "Z:") ) ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted April 24, 2017 Share Posted April 24, 2017 @Roy, I'd use: _$ (mapcar (function (lambda (x) (strcat x ":"))) (mapcar 'chr (vl-string->list "ABCDEFGHIJKLMNOPQRSTUVWXYZ"))) ("A:" "B:" "C:" "D:" "E:" "F:" "G:" "H:" "I:" "J:" "K:" "L:" "M:" "N:" "O:" "P:" "Q:" "R:" "S:" "T:" "U:" "V:" "W:" "X:" "Y:" "Z:") This is not a big deal, just for the lazy code writers. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 24, 2017 Share Posted April 24, 2017 Another. (defun Drives ( / i d l ) ;; Tharwat - Date: 24.Apr.2017 ;; (setq i 64) (while (< i 91) (if (vl-file-directory-p (setq d (strcat (chr (setq i (1+ i))) ":"))) (setq l (cons d l))) ) (vl-sort l '<)) Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted April 24, 2017 Author Share Posted April 24, 2017 you guys are wonderful people. alot to think about! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 24, 2017 Share Posted April 24, 2017 Here's another, using Windows Management Instrumentation: (defun LM:wmidriveletters ( / qry rtn srv wmi ) (if (setq wmi (vlax-create-object "wbemscripting.swbemlocator")) (progn (vl-catch-all-apply '(lambda ( ) (vlax-for itm (setq srv (vlax-invoke wmi 'connectserver) qry (vlax-invoke srv 'execquery "SELECT DeviceID FROM Win32_LogicalDisk") ) (vlax-for prp (vlax-get itm 'properties_) (if (= "DeviceID" (vlax-get prp 'name)) (setq rtn (cons (vlax-get prp 'value) rtn)) ) ) ) ) ) (foreach obj (list qry srv wmi) (if (= 'vla-object (type obj)) (vlax-release-object obj) ) ) (vl-sort rtn '<) ) ) ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted April 24, 2017 Share Posted April 24, 2017 Here's another, using Windows Management Instrumentation: Makes me wonder, how do you know so much about COM ? Is this is your main resource? Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted April 24, 2017 Author Share Posted April 24, 2017 The following function will return a list of the drive letters in use:;; Drive Letters - Lee Mac ;; Returns a list of drive letters currently in use (defun LM:driveletters ( / fso rtn ) (if (setq fso ([b][color="red"]vlax-create-object "scripting.filesystemobject"[/color][/b])) (progn (vl-catch-all-apply '(lambda ( ) (vlax-for obj (vlax-get fso 'drives) (setq rtn (cons (vlax-get obj 'driveletter) rtn)) ) ) ) (vlax-release-object fso) (vl-sort rtn '<) ) ) ) Also posted here: https://www.theswamp.org/index.php?topic=47396.msg524127#msg524127 okay, wtf!? How does one even know that stuff is available? I did a google search on "scripting.filesystemobject" and this is what I found FileSystemObject Is this a list of properties i can access via "vlax-create-object"? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 25, 2017 Share Posted April 25, 2017 This may be usefull, note the first part which checks for directories ie drives. ; resets the paths usefull for update versions of Autocad ; by A H 2011 ; This sets a reference to the install path of your product ; the gets are their for info maybe other use ; use this to find other settings ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) (vl-load-com) (defun setpaths ( / *files* doc) ; make temp directory (if (vl-file-directory-p "C:\\Acadtemp\\") (Princ "Acadtemp exists") (vl-mkdir "C:\\AcadTEMP\\") ) (setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) ; savepath ;(vla-get-AutoSavepath *files*) (vla-put-AutoSavepath *files* "C:\\AcadTemp") ; custom icons ;(vla-get-CustomIconPath *files*)) (vla-put-CustomIconPath *files* "P:\\Autodesk\\ICONS") ; custom menu ;(vla-get-Menufile *files*)) ;(vla-put-Menufile *files* "C:\\Users\\2013COGG") ; printers config ;(vla-get-PrinterConfigPath *files*) (vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011") ; printers style sheet ;(vla-get-PrinterStyleSheetPath *files*) (vla-put-PrinterStyleSheetPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles") ; printer drv's ;(vla-get-PrinterDescPath *files*) (vla-put-PrinterDescPath *files* "P:\\AutoDESK\\Plotting\\Drv") ; print spooler ;(vla-get-PrintSpoolerPath *files*) (vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\") ; template path ;(vla-get-TemplateDwgPath *files*) (vla-put-TemplateDwgPath *files* "P:\\Autodesk\\c3d Templates") ; template location ;(vla-get-QnewTemplateFile *files*) (vla-put-QnewTemplateFile *files* "P:\\Autodesk\\c3d Templates\\gg.dwt") ;make new support paths exist + new (setq paths (vla-get-SupportPath *files*)) (setq coggpaths "P:\\autodesk\\supportfiles;P:\\autodesk\\lisp;P:\\autodesk\\fonts;") (setq newpath (strcat coggpaths paths)) (vla-put-SupportPath *files* newpath) ; Tempdirectory ;(vla-get-TempFilePath *files*)) (vla-put-TempFilePath *files* "C:\\AcadTemp\\") ; PlotLogFilePath = "C:\\Documents and Settings\\ah\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\") ; LogFilePath = "C:\\Documents and Settings\\ah\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-LogFilePath *files* "C:\\AcadTemp\\") ; xref temp path ;(vla-get-TempXrefPath *files*)) (vla-put-TempXrefPath *files* "C:\\AcadTemp\\") ; end use of *files* ) (setpaths) ; exit quitely (princ "All Done") Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 25, 2017 Share Posted April 25, 2017 Makes me wonder, how do you know so much about COM ? Is this is your main resource? Yes - the full WMI reference may be found here. okay, wtf!? How does one even know that stuff is available? I did a google search on "scripting.filesystemobject" and this is what I found FileSystemObject Is this a list of properties i can access via "vlax-create-object"? The link to which you refer is a list of the properties available for an instance of the FileSystemObject (FSO). The vlax-create-object function allows you to instantiate a class, allowing you to access the properties & methods of the class. Quote Link to comment Share on other sites More sharing options...
Grrr Posted April 25, 2017 Share Posted April 25, 2017 Yes - the full WMI reference may be found here. Thanks for clarifying Lee! - you are too advanced in every aspect of LISP... Quote Link to comment Share on other sites More sharing options...
jscgvnc Posted April 25, 2017 Share Posted April 25, 2017 Lee seems to know everything about everything. Seriously, I haven't seen a problem yet he couldn't lick. Quote Link to comment Share on other sites More sharing options...
