DuanJinHui Posted April 24, 2017 Share Posted April 24, 2017 How compare 2 obj ? if the same ,return T , not same , return nil Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 24, 2017 Share Posted April 24, 2017 Since every object has a unique handle property, strictly speaking, identical objects do no exist... First compare the objectname property of the two objects. If they have the same object name: Use the atoms-family function to get a list of all functions. Filter for "vla-get-*" functions and compile a list of all properties (skip the handle property). Check which properties are available (vlax-property-available-p) for the objects and compare values. Perhaps use vl-every to do so efficiently. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 25, 2017 Share Posted April 25, 2017 Like Roy_043 some of the obvious line,arc,circle,pline layer, length,area you need to provide more information about what you are comparing, solids are different again. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted April 25, 2017 Author Share Posted April 25, 2017 I Know , (equal e1 e2) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 25, 2017 Share Posted April 25, 2017 In its simplest, most primitive, form the function could look like this: ; (CompareEntities_P (car (entsel)) (car (entsel))) (defun CompareEntities_P (enm1 enm2 / elst1 elst2) (setq elst1 (entget enm1)) (setq elst2 (entget enm2)) (and (= (length elst1) (length elst2)) (vl-every '(lambda (sub1 sub2) (cond ((/= (car sub1) (car sub2)) nil ) ((vl-position (car sub1) '(-1 5)) ; Skip ename and handle. T ) (T (equal sub1 sub2 1e- ) ) ) elst1 elst2 ) ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 25, 2017 Share Posted April 25, 2017 This example may offer some ideas - the example demonstrates a possible method of selecting blocks with similar geometry, but the idea could be translated to primary objects. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted April 25, 2017 Share Posted April 25, 2017 @Lee: Interesting solution, but with a chance of false positives. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 25, 2017 Share Posted April 25, 2017 @Lee:Interesting solution, but with a chance of false positives. Thanks Roy, though a stricter comparison may miss valid results - this form of function is notoriously ambiguous. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted April 26, 2017 Author Share Posted April 26, 2017 In its simplest, most primitive, form the function could look like this: ; (CompareEntities_P (car (entsel)) (car (entsel))) (defun CompareEntities_P (enm1 enm2 / elst1 elst2) (setq elst1 (entget enm1)) (setq elst2 (entget enm2)) (and (= (length elst1) (length elst2)) (vl-every '(lambda (sub1 sub2) (cond ((/= (car sub1) (car sub2)) nil ) ((vl-position (car sub1) '(-1 5)) ; Skip ename and handle. T ) (T (equal sub1 sub2 1e- ) ) ) elst1 elst2 ) ) ) Thank you Roy, Quote Link to comment Share on other sites More sharing options...
