I m having an issue with my lisp code for a DCL dialog box I made. It seems my string is too long for action_tile "accept" and I m getting error "bad argument type: lselsetp nil". The problem is, apparently, that I have too many input values that makes it long. If I remove one or two lines it works but I need to get them all in, store them and do validation checking.
Is there a way to make it work like spiting the string or maybe rewrite it better to alleviate the problem?
Any suggestions will be appreciated.
Here is the section I m talking about.
(action_tile "accept"
	(strcat
		"(progn
			(setq lfm_ (get_tile \"lfm\"))
			(setq lfv_ (get_tile \"lfv\"))
			(setq lhd_ (get_tile \"lhd\"))
			(setq lbl_ (get_tile \"lbl\"))
			(setq nhb_ (get_tile \"nhb\"))
			(setq nbl_ (get_tile \"nbl\"))
			(setq los_ (get_tile \"los\"))
			(setq lor_ (get_tile \"lor\"))
			(setq lom_ (get_tile \"lom\"))
			(setq nsr_ (get_tile \"nsr\"))
			(setq orient_ (nth (atoi (get_tile \"orient\")) orientls))
			(setq sud_ (nth (atoi (get_tile \"sud\")) sudls))
			(setq rbn_ (get_tile \"rbn\"))
			(setq ris_ (get_tile \"ris\"))
			(setq off_ (get_tile \"off\"))
			(cond
				((or (not (distof lfm_)) (<= (atof lfm_) 0))
					(set_tile \"error\" \"Invalid input!\")
					(mode_tile \"lfm\" 2)							; set focus on error item
				((or (not (distof lfv_)) (<= (atof lfv_) 0))
					(mode_tile \"lfv\" 2)							; set focus on error item
				((or (not (distof lhd_)) (<= (atof lhd_) 0))
					(mode_tile \"lhd\" 2)							; set focus on error item
				((or (not (distof lbl_)) (<= (atof lbl_) 0))
					(mode_tile \"lbl\" 2)							; set focus on error item
				((or (not (distof nhb_)) (vl-string-position (ascii \".\") nhb_) (<= (atof nhb_) 0))
					(mode_tile \"nhb\" 2)							; set focus on error item
				((or (not (distof nbl_)) (vl-string-position (ascii \".\") nbl_) (<= (atof nbl_) 0))
					(mode_tile \"nbl\" 2)							; set focus on error item
				((or (not (distof los_)) (<= (atof los_) 0))
					(mode_tile \"los\" 2)							; set focus on error item
				((or (not (distof lor_)) (<= (atof lor_) 0))
					(mode_tile \"lor\" 2)							; set focus on error item
				((or (not (distof lom_)) (<= (atof lom_) 0))
					(mode_tile \"lom\" 2)							; set focus on error item
				((or (not (distof nsr_)) (vl-string-position (ascii \".\") nsr_) (<= (atof nsr_) 0) (> (atoi nsr_) (atoi nhb_)))
					(mode_tile \"nsr\" 2)							; set focus on error item
				(t (done_dialog) (setq userclick T))
Heres my suggestion, it could be shortened more:
 (vl-prin1-to-string
   '(progn
     (mapcar 'set '(lfm_ lfv_ lhd_ lbl_ nhb_ nbl_ los_ lor_ lom_ nsr_ rbn_ ris_ off_)
       (mapcar 'get_tile '("lfm" "lfv" "lhd" "lbl" "nhb" "nbl" "los" "lor" "lom" "nsr" "rbn" "ris" "off"))
     (setq orient_ (nth (atoi (get_tile "orient")) orientls))
     (setq sud_ (nth (atoi (get_tile "sud")) sudls))
     (or
       (and (set_tile "error" "Invalid input!")
         (vl-some (function (lambda (x) (if (eval (car x)) (mapcar 'eval (cdr x)))))
           '(( (or (not (distof lfm_)) (<= (atof lfm_) 0)) (mode_tile "lfm" 2) )
             ( (or (not (distof lfv_)) (<= (atof lfv_) 0)) (mode_tile "lfv" 2) )
             ( (or (not (distof lhd_)) (<= (atof lhd_) 0)) (mode_tile "lhd" 2) )
             ( (or (not (distof lbl_)) (<= (atof lbl_) 0)) (mode_tile "lbl" 2) )
             ( (or (not (distof nhb_)) (vl-string-position (ascii ".") nhb_) (<= (atof nhb_) 0)) (mode_tile "nhb" 2) )
             ( (or (not (distof nbl_)) (vl-string-position (ascii ".") nbl_) (<= (atof nbl_) 0)) (mode_tile "nbl" 2) )
             ( (or (not (distof los_)) (<= (atof los_) 0)) (mode_tile "los" 2) )
             ( (or (not (distof lor_)) (<= (atof lor_) 0)) (mode_tile "lor" 2) )
             ( (or (not (distof lom_)) (<= (atof lom_) 0)) (mode_tile "lom" 2) )
             ( (or (not (distof nsr_)) (vl-string-position (ascii ".") nsr_) (<= (atof nsr_) 0) (> (atoi nsr_) (atoi nhb_))) (mode_tile "nsr" 2) )
           ); list
         ); vl-some
       ); and
       (setq userclick (done_dialog))
     ); or
   ); progn
 ); vl-prin1-to-string
); action_tile
However I'm not sure that this is the cause of the error.
EDIT:
Shortening, such as replacing the (vl-some) block, with:
(or
 (vl-some (function (lambda (x) (if (or (not (distof (car x))) (<= (atof (car x)) 0)) (mode_tile (cadr x) 2))))
   '((lfm_ "lfm") (lfv_ "lfv") (lhd_ "lhd") (lbl_ "lbl") (los_ "los") (lor_ "lor") (lom_ "lom"))
 (vl-some (function (lambda (x) (if (or (not (distof (car x))) (vl-string-position (ascii ".") (car x)) (<= (atof (car x)) 0)) (mode_tile (cadr x) 2))))
   '((nhb_ "nhb") (nbl_ "nbl"))
 (if (or (not (distof nsr_)) (vl-string-position (ascii ".") nsr_) (<= (atof nsr_) 0) (> (atoi nsr_) (atoi nhb_))) (mode_tile "nsr" 2) )
); or
MJLM
Usually, each tile has it's own action, like this:
(action_tile "lfm" "(setq lfm_ $value) (err $key $value)")
(action_tile "lfv" "(setq lfv_ $value) (err $key $value)")
If you like, you can use this:
(mapcar
 '(lambda (key var)
    (action_tile key
      (strcat
        (vl-prin1-to-string (list 'setq var '$value))
        (vl-prin1-to-string '(err $key $value))
 '("lfm" "lfv" "lhd" "lbl" "nhb" "nbl" "los" "lor" "lom" "nsr" "orient" "sud" "rbn" "ris" "off")
 '(lfm_ lfv_ lhd_ lbl_ nhb_ nbl_ los_ lor_ lom_ nsr_ orient_ sud_ rbn_ ris_ off_)
The error function called in each tile, can be like this:
(defun err (key val / n)
 (if
   (or
     (not (setq n (distof val)))
     (minusp n)
     (mode_tile key 2)
Of course, you have to set the error function to fit your need.
By default, "accept" exit with value 1 and "cancel" with 0, but it is not wrong to assign an action to these tiles.
I would prefer to use this schema:
(setq r (start_dialog))
(unload_dialog dcl_ID)
(if
 (= r 1)
 (do_some_stuff lfm_ lfv_ ..... )
@Grrr,
thank you, you first suggestion works great and it have helped me to understand how can I consolidate my code a bit. However your second suggestion, which I prefer, does not seem to work. I replaced the vl-sort block but I just cant make it work.
@Stefan,
thank you. The implementation of your method seems easier but when i tried to do it I was getting errors with my variables while converting to reals with atof.
EDIT: Ok, I managed to fixed that and it s working OK now.
Edited by MJLM
Another, untested:
   (vl-prin1-to-string
      '(if
           (not
               (vl-some
                  '(lambda ( pat lst )
                       (vl-some
                          '(lambda ( key )
                               (if (wcmatch (get_tile key) pat)
                                       (mode_tile key 2)
                           lst
                  '("*[~.0-9]*,*`.*`.*" "*[~0-9]*")
                  '(("lfm" "lfv" "lhd" "lbl" "los" "lor" "lom") ("nhb" "nbl" "nsr" "rbn" "ris" "off"))
           (done_dialog 1)
Jesus! for a moment I though you were just throwing gibberish just for fun. :P
Thanks Lee. I will try your way too.
My main problem with this DCL is that I cannot follow the steps while executing inside the visual lisp editor. When I run the code the program does not break on error and I cannot know what is going wrong. Am I doing something wrong here or DCL sucks so much?
@MJLM,
just curios did Lee's suggestion work?
@Lee,
I know that you usually use the if function, but note that
(if (not <test expr>) <then expr>)
could be shortened a bit, to:
(or <test expr> <then expr>)
Although awesome suggestion, I'll keep it if MJLM confirm that it works.
I tried to implement Lee's way but I think there is something going wrong with the pattern ("*[~.0-9]*,*`.*`.*" "*[~0-9]*"). I get "invalid input" for almost all boxes.
The pattern checks for numerical input in the decimal format. Your comment suggests you are working in the imperial format.
No, not really. I m working in metric with just reals and integers.
