MR MAN Posted January 13, 2009 Posted January 13, 2009 how can i make 3d mesh lisp take in mind that osnap turn off when using command 3d then mesh, i want use endpoint? Quote
togores Posted December 20, 2012 Posted December 20, 2012 you can watch my class at Autodesk University 2012, LISP your MESH into Shape! It shows how to use entmake and entmod to create and modify 3d meshes Quote
David Bethel Posted December 20, 2012 Posted December 20, 2012 ;*** means the group is required To entmake a mesh, 1st you must make the HEADER : (entmake (list (cons 0 "POLYLINE") ;*** (cons 6 "BYLAYER") (cons 8 "0") (cons 10 (list 0.0 0.0 0.0)) ;*** (cons 39 0.0) (cons 40 0.0) (cons 41 0.0) (cons 62 256) (cons 66 1) ;*** (cons 70 16) ;*** (cons 71 2) ;*** (cons 72 2) ;*** (cons 73 0) (cons 74 0) (cons 75 0) (cons 210 (list 0.0 0.0 1.0)))) For each VERTEX : (entmake (list (cons 0 "VERTEX") ;*** (cons 6 "BYLAYER") (cons 8 "0") (cons 10 (list 0.0 0.0 0.0)) ;*** (cons 39 0.0) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 50 0.0) (cons 70 64) ;*** (cons 71 0) (cons 72 0) (cons 73 0) (cons 74 0) (cons 62 256))) The SEQEND entity : (entmake (list (cons 0 "SEQEND") ;*** (cons 8 "0"))) A PFACE mesh has different logic, so watch your step there. The trick is in knowing the correct value for the required groups Header group 66: 1 bit MUST be set Header group 70: 16 bit MUST be set for closed M direction, add the 1 bit for closed N direction, add the 32 bit Header group 71: M mesh count Header group 72 N mesh count Vertex group 70: 64 bit MUST be set These are pretty much the bare minimums How you collect or construct the point list pretty much arbitrary as long as you feed them to the vertex call in the proper order and quantity. Just keep in mind that they are WCS point values. -David Quote
David Bethel Posted December 20, 2012 Posted December 20, 2012 WOW I didn't realize how old this thread was gggrrrrr Quote
David Bethel Posted December 20, 2012 Posted December 20, 2012 And an advertisement reply to boot ! Sucked me in Quote
togores Posted December 20, 2012 Posted December 20, 2012 I hadn't realized that post's age. Found it in Google. You are describing how to entmake legacy Polygon or Polyface meshes. If you watch my AU 2012 class (call it an advertisement if you wish) you'll find out how to entmake the new MESH (not POLYLINE variants) entities. And to modify them through entmod. Quote
David Bethel Posted December 21, 2012 Posted December 21, 2012 (call it an advertisement if you wish) If it's self promoting and ain't free, it's an advertisement to me. Quote
togores Posted December 22, 2012 Posted December 22, 2012 (edited) I am including a link to the handout for my AU2012 class in which the source code for entmake-ing/entmod-ing MESH (SubDMesh) entities is explained. I hope this will clear any misunderstanding. https://docs.google.com/open?id=0B9W7tCC4QFV7blpRcExhRkxvS3M If anyone is interested in watching the videos, the link is: http://au.autodesk.com/?nd=au_player#1%0:3202 Best regards, Reinaldo N. Togores University of Cantabria, Spain. Edited January 11, 2013 by togores The docs.google.com link has been changed Quote
