Creating rotating dynamic blocks with persistently horizontal attributes
SOliver
Hi all
I am hoping to create a block which has two components, a drafted entity and a set of attributes.
The thing is, I need to make it so that when you rotate the entity the attributes remain horizontal, below the entity.
Is this possible?
Thanks,
SOliver.
Looks like an simple 'rotation' action with only selecting the entity to rotate would to the trick?
test.dwg
When you create your block and add the attributes make sure the attributes are annotative. This way they will maintain their horizontal reference to the x-axis. Next insert a rotate parameter to the block, then a rotate action and select everything. Your not done just yet, place a point parameter for each attribute you have in the center of each attribute. Apply a move action and select just the points and attributes. You will have to tweak this a little to get the attributes to behave like you want them too by moving the point parameter around a bit. If you get confused use this block as a reference.
Notification Wall Mount System Sensor.dwg
