Hello all!
First time posting here, and I need help. I am just delving into lisps and this quick one I wrote seems to be broken.
;;SELECT ALL
(defun c:SA ()
(command "_.select" "_all")
It selects all items in my drawing as asked, but then I can't enter another command after it (no way to move/copy/delete-etc.). What am I missing and if it's not to much please fill me in on why it's not working.
Thank you!
;;SELECT ALL
(defun c:SA ()
Sorry about that and thank your for the head's up!
The select command allows you to use "previous" in other commands like move, copy, etc., by entering the letter "p" (no quotes) when asked for the selection.
In your example, you would need to add a double quote to end the command:
(command "_.select" "_all" [color=red]""[/color])
Or, if you want to add say, the move command to your code, you could do something like this:
(command "_.select" "_all" "" ".move" "p" "" pause pause)
Edited by BKT
It seems to not select anything now or perhaps it is selecting all and then finishes the command and thus I cannot manipulate them.
;;SELECT ALL
(defun c:SA ()
 (command "_.select" "_all" "")
This was after I updated from your input.
Maybe I wasn't clear - the SELECT command just creates a selection set. Once that's done, you can manipulate them, but you'll need to call whatever command you want after that. In the second piece of code I posted above as an example, the MOVE command is combined with SELECT so you could move all entities by picking points.
If you wanted to do a MOVE, for example, you could also use a simple line of code like this:
(command "._move" "ALL" "" pause pause)
If you want to manipulate the entities selected you'll need to add more to the code.
If I type in the normal commands "Select" and "All" and hit enter to confirm my selection, I can then tell it what I want to do with my selection (such as move/copy/delete-etc.). It does appear I am out of the select command, but they are all selected and ready for the appropriate noun-verb command prompt to do something else.
How can I make my lisp do essentially "select" "all" "enter" - to have everything selected to then be modified by whatever command I choose to do next?
After you run your posted code, everything is in a selection set. Just do a MOVE (or whatever) command and enter P for previous selection and the set you created will be selected.
Try:
;;SELECT ALL
(defun c:SA ()
 (setq ss(ssget "X"))
 (sssetfirst nil ss)
Why is this LISP necessary?
I think I understand now what is happening with the code I was using.
The code you provided tombu works just like I wanted it to, but now I wonder what is different about your code than mine as far as how it works?
This is more for my understanding of how basic lisps work more than anything else. I have quite a few I've searched for and use daily, and trying to write my own based on those codes is very rough.
There's a lot of selection options available in lisp, see online help AutoLISP functions:
Check out all the options for SSGET and all the GETXXXXXXXX functions.
As a rule I'd avoid using the COMMAND function unless you have to.
Another example
;;move ALL
(defun c:mall( / ss)
 (command "Move" ss "" (getpoint)(getpoint))
