Good morning,
Is there something similar to a while loop that will exit the loop part way through if the condition is reached?
For example
 (setq test 0)
 (while (<= test 10)
   (setq test (1+ test))
   (princ test)
   (princ test)
   (princ test)
Will return a count in the command line, 1 to 12, then the next time round 'while' sees 'test' is greater than 10 and doesn't do the loop again.
What I am wanting is the loop to count 1 to 10, then exit the while loop.
So is there anything simple that will do this?
Thanks
Hi,
As long as you have specific number of loops then you can use REPEAT function but while function also should work.
(repeat 10
(while <test statement> [color="green"]; if true, do the expressions below, if false - don't evaluate the expressions/stop the loop[/color]
 <expressions> [color="green"]; evaluate the expressions, and run the <test statement> again[/color]
Whats happening is that you are incrementing the value 3 times per check, I think that you have to increase the value once at every check:
(setq n 0)
(while (< n 10)
 (setq n (1+ n))
 (print n)
Or check the every sub-increment, which is frustrating:
(setq n 0)
(while (<= n 10)
 (while (<= (setq n (1+ n)) 10)
   (print n)
     (print n)
       (print n)
But if you really just want to increment like that, use repeat function like Tharwat mentioned (its the fastest).
Thanks, perhaps I should have explained it better. Replace (setq test (1+ test)) with calls to other subroutines, each of these might take Test to above 10 sometime, but I don't want the subsequent sub routines to run when it does (for example 1st loop, routine_1 and test = 3, routine_2, test = 5, routine_3 test = 8, 2nd loop, routine 1 and test = 9 routine_2 test = 12 so stop loop before routine_3 is called)
Tharwat - repeat works well for how I first described my problem, thanks
Grrr - I want to do the frustrating method but in a less frustrating manner
Maybe something like this?
(setq test 0)
(while
   (and
       (< test 11)
           (< test 11)
           (< test 11)
           (< test 11)
Thanks Lee, as always a great solution, I never knew you could add 'and' to a while command like that
You're welcome Steven - any expression can constitute the test expression for a while loop. :thumbsup:
