I have put together the code below and it is giving me the following error:
error: bad argument type: lentityp
Process Entities By Numerical Portion of Layer Name:
(defun c:DEMO (/ z s i e ln w)
(vl-load-com)
(defun numbers-from-string (str)
 (defun num-char-p (char)
   (< 48 char 57)
 ) ;_ end of defun
 (vl-list->string
   (vl-remove-if-not
     'num-char-p
     (vl-string->list str)
   ) ;_ end of vl-remove-if-not
 ) ;_ end of vl-list->string
) ;_ end of defun
 (setq z '(100 125 150 175 200 225 250 275 300))
 (if (setq s (ssget ":L" '((0 . "LWPOLYLINE"))))
  (repeat (setq i (sslength s))
     (setq e (entget (ssname s (setq i (1- i)))))
     (setq ln (cdr (assoc 8 e))
        w  (* (car (member (atoi (numbers-from-string ln)) z)) 0.001)
     ) ;_ end of setq
     (vla-put-ConstantWidth (vlax-ename->vla-object e) w )
     (ssdel e s)
   ) ;_ end of repeat
 ) ;_ end of if
) ;_ end of defun
Can anybody help, please?
Thanks in advance
Edited by abra-CAD-abra
Try this, the vlax ename does not like a entget
(setq obj (vlax-ename->vla-object (ssname s (setq i (1- i)))))
 (setq ln (vla-get-layer obj)
 ;    (setq ln  ln (cdr (assoc 8 (entget e)))
     ) ;_ end of setq
(vla-put-ConstantWidth obj w )
     ) ;_ end of setq
Perfect!!!
Thanks BIGAL :)
BTW I was still thinking that the NumbersFromString subfunction should be written like this:
;_$ (mapcar 'cadr
;   (vl-sort
;     (vl-remove 'nil
;       (mapcar '(lambda (x / n) (if (setq n (NumberFromString x T)) (list n x) (list 0 x)) )
;         '("A1B" "ABC" "A17" "AB14.5B.C" "DEF" "A1.5B" "A16.BC")
;     '(lambda (a b) (< (car a) (car b)))
; -> ("ABC" "DEF" "A1B" "A1.5B" "AB14.5B.C" "A16.BC" "A17")
; _$ (NumberFromString "12345" nil) -> 12345
; _$ (NumberFromString "12345" T) -> 12345
; _$ (NumberFromString "A.B.C,D,E" nil) -> nil
; _$ (NumberFromString "A.B.C,D,E" T) -> nil
; _$ (NumberFromString "A1.B2.C3,D4,E5" nil) -> 12345
; _$ (NumberFromString "A1.B2.C3,D4,E5" T) -> 1.2345
(defun NumberFromString ( s RetainFirstDot )
 (cond
   ( (not (eq 'STR (type s))) )
   ( (not (vl-some (function (lambda (x) (< 47 x 58))) (vl-string->list s))) (setq s nil) )
   (RetainFirstDot
     (setq s (vl-list->string (vl-remove-if-not (function (lambda (x) (or (= x 46) (< 47 x 58)))) (vl-string->list s))))
     (while (or (= "" s) (and (vl-some (function (lambda (x) (< 47 x 58))) (vl-string->list s)) (not (numberp (read s))))) ; attempt to retain the very first dot, but can return ".."
       (setq s (vl-list->string (reverse (vl-string->list (vl-string-subst "" "." (apply 'strcat (reverse (mapcar 'chr (vl-string->list s)))))))))
     ); while
   ); RetainFirstDot
   ( (setq s (vl-list->string (vl-remove-if-not (function (lambda (x) (< 47 x 58))) (vl-string->list s)))) )
 ); cond
 (cond ((not s) s) ((vl-every '(lambda (x) (= x 46)) (vl-string->list s)) nil)((= "" s) nil) (s (read s)))
); defun NumberFromString
Atleast if it has a alphanumerical string sorting purpose.
Edited by Grrr
Check should be: (< 47 x 58), not (< 48 x 57) - to include zeros
Here's another version of a 'Numbers from String' function: Parse Numbers - though the desired result for some inputs may depend on the application.
...though the desired result for some inputs may depend on the application.
Thinking carefully, you are very correct about this.
And makes me think to figure out such function:
_$ (foo "1abc-2.3b4cdef56")
(1 "abc" -2.3 "b" 4 "cdef" 56)
That way it could be used more globbaly, so one could rule out/in with which (nth) items to work with.
Thank you all for your assistance.
Lee/Grrr,
Since the output layer names only contain a single occurence of a number, for example; "THIS-IS-LAYER-125". I only need to parse that single occurence and I only require numbers (0-9) and not mathematical operators or special characters.
Lee, I did try your parse numbers function however, it includes mathematical operators such as "-" (minus). I didn't want to start hacking at your code.
BIGAL,
After a little study and help from Lee's Visual Lisp ActiveX tutorials (http://www.lee-mac.com/selsetprocessing.html#activex), I have updated the code to VLA to avoid the need to convert each entity to its equivalent VLA-Object representation. Great tutorials, Lee!
(defun c:DEMO (/ z s ln w)
 (vl-load-com)
     (< 47 char 57)
   ) ;_ end of defun
   (vl-list->string
     (vl-remove-if-not
'num-char-p
 ) ;_ end of defun
 (if (setq s (ssget "_:L" '((0 . "LWPOLYLINE"))))
     (vlax-for o (setq
     s (vla-get-activeselectionset
  (vla-get-activedocument (vlax-get-acad-object))
       ) ;_ end of vla-get-activeselectionset
   ) ;_ end of setq
(setq ln (vla-get-layer o)
) ;_ end of setq
(vla-put-ConstantWidth o w)
     ) ;_ end of vlax-for
     (vla-delete s)
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
abra-CAD-abra,
You don't need to "hack" Lee's code, just manipulate the output a bit:
_$ (LM:parsenumbers "THIS-IS-LAYER-125")
(-125)
_$ (abs (last (LM:parsenumbers "THIS-IS-LAYER-125")))
125
_$ (LM:parsenumbers "Pipes300-Layer-125")
(300 -125)
_$ (abs (last (LM:parsenumbers "Pipes300-Layer-125")))
125
Then you could use:
(setq w (* (car (member (abs (last (LM:parsenumbers ln))) z)) 1e-3))
However your code should work fine without Lee's function, for the situation you described. Just be careful for a polylines on a layer that does not have numerical occurrence:
(and
 (setq ln (vla-get-Layer o))
 (setq w (numbers-from-string ln)) ; _$ (numbers-from-string "layer") -> ""
 (/= "" w) ; _$ (atoi "") -> 0
 (setq w (* (car (member (atoi w) z)) 0.001))
); and
abra-CAD-abra,
(-125)
125
(300 -125)
125
Then you could use:
(and
); and
Thanks for your help and advice, Grrr. I will update the code to allow for polylines on layers without a numerical occurence.
Cheers
