I have lot of hatch patterns for autocad. I want to use them in Photoshop. While trying to load the pat file, photoshop says that it is bad or corrupted. On the contrary, they work pretty fine in Autocad. What's the solution to this? I am using Autocad 2017, and Photoshop cc 2017
I don't think Autocad .pat files are the same as Photoshop .pat files.
If you want to use your Autocad hatches in Photoshop, you will have to create a hatch, print to pdf, open pdf in Photoshop and make it a pattern.
