Guest Posted May 16, 2017 Posted May 16, 2017 Hi. I am trying to make a lisp to work through dcl with slides I have a lisp file with 4 different lisp codes and i have one dcl file with 4 slides.I want when i click the slide the routine runs. look the attach *.zip file Thanks intersections.rar Quote
Grrr Posted May 16, 2017 Posted May 16, 2017 There are some issue(s) in your dcl code, in the 2nd row its missing a double quote, and after you define the dialog there are included are few spacers with the ok_cancel and errtile. I think it should be formatted like this: intersections : dialog { label = "ΚΑΤΑΣΚΕΥΕΣ ΣΗΜΕΙΩΝ Topocad 2017"; spacer_1; : text_part { label = "Επιλέξτε είδος Κατασκευής Σημείου :" ; alignment = left; } spacer_1; : row { children_height = 8.0; children_width = 29.0; children_fixed_width = true; children_fixed_height = true; : image_button { key = "me" ; color = graphics_background; } : image_button { key = "te" ; color = graphics_background; } } : row { children_height = 8.0; children_width = 29.0; children_fixed_width = true; children_fixed_height = true; : image_button { key = "pse" ; color = graphics_background; } : image_button { key = "tk" ; color = graphics_background; } } spacer_1; ok_cancel; : errtile { width = 34; } } Quote
Guest Posted May 16, 2017 Posted May 16, 2017 Hi Grrr.Thank for the reply.i do the change but is still not load dcl file Quote
BIGAL Posted May 17, 2017 Posted May 17, 2017 I had a quick look and you dont seem to be starting the image process and implying which image goes in which square. I will try to find some example code. (start_image "icon_noi") (slide_image 0 0 (- (dimx_tile "icon_noi") 1) (- (dimy_tile "icon_noi") 1) "BIG-ALblank") (end_image) Quote
Guest Posted May 17, 2017 Posted May 17, 2017 hi BIGAL .Can you show me an example because i can not understand it..... Thanks Quote
Grrr Posted May 17, 2017 Posted May 17, 2017 I was wrong about children_height = 8.0; and children_width = 29.0; attributes, however heres an example: ; Slides Example (defun C:test ( / L *error* dcl des dch dcf slidefiles r ) (setq L '( ("te" ; inter ( (lambda ( / o1 o2 ) (and (setq o1 (car (entsel "\nFirst Object: "))) (setq o2 (car (entsel "\nSecond Object: "))) (foreach p (LM:Intersections (vlax-ename->vla-object o1) (vlax-ename->vla-object o2) acextendboth) (entmake (list '(0 . "POINT") (cons 10 p))) ) ) ) ) ) ("tk" ; interset ( (lambda ( SS ) (if SS (foreach p (LM:intersectionsinset SS) (entmake (list '(0 . "POINT") (cons 10 p))) ) ) ) (progn (princ "\nSelect objects to intersect: ") (ssget) ) ) ) ("pse" ; perpt ( (lambda ( / dis enx pt1 pt2 pt3 sel tmp ) (while (not (progn (setvar 'errno 0) (setq sel (entsel "\nSelect line or polyline segment: ")) (cond ( (= 7 (getvar 'errno)) (prompt "\nMissed, try again.") ) ( (null sel) ) ( (= "LINE" (cdr (assoc 0 (setq enx (entget (car sel)))))) (setq pt1 (trans (cdr (assoc 10 enx)) 0 1) pt2 (trans (cdr (assoc 11 enx)) 0 1) dis (distance pt1 pt2) ) ) ( (= "LWPOLYLINE" (cdr (assoc 0 enx))) (setq tmp (vlax-curve-getclosestpointto (car sel) (trans (cadr sel) 1 0)) tmp (fix (+ 1e-8 (vlax-curve-getparamatpoint (car sel) tmp))) pt1 (trans (vlax-curve-getpointatparam (car sel) tmp) 0 1) pt2 (trans (vlax-curve-getpointatparam (car sel) (1+ tmp)) 0 1) dis (distance pt1 pt2) ) ) ( (prompt "\nThe selected object is not a line or 2D polyline.") ) ) ) ) ) (if (and pt1 pt2 (setq pt3 (getpoint "\nSpecify 3rd point: "))) (entmake (list '(000 . "POINT") '(008 . "section") (cons 010 (trans (polar pt1 (angle pt1 pt2) (apply '+ (mapcar '* (mapcar '- pt3 pt1) (mapcar '(lambda ( a b ) (/ (- a b) dis)) pt2 pt1) ) ) ) 1 0) ) (cons 210 (trans '(0 0 1) 1 0 t)) ) ) ) (princ) ) ) ) ("me" ; MidPl ( (lambda ( / e enx o prm mp ) (and (setq e (car (entsel "\nSelect line: "))) (setq enx (entget e)) (member (cdr (assoc 0 enx)) '("POLYLINE" "LWPOLYLINE" "LINE")) (setq o (vlax-ename->vla-object e)) (setq prm (vlax-curve-getEndParam o)) (setq mp (vlax-curve-getPointAtDist o (* 0.5 (vlax-curve-getDistAtParam o prm)))) (entmake (list '(0 . "POINT") (cons 10 mp))) (princ (strcat "\nPoint object created at mid-point: " (vl-prin1-to-string mp))) (princ) ) ) ) ) ); list ); setq L (defun *error* ( msg ) (and (< 0 dch) (unload_dialog dch)) (and (eq 'FILE (type des)) (close des)) (and (eq 'STR (type dcl)) (findfile dcl) (vl-file-delete dcl)) (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)) )) (princ) ); defun *error* (cond ( (progn (setq slidefiles (mapcar '(lambda (x) (strcat x ".sld")) '("me" "te" "pse" "tk"))) ; <- adjust slidernames (vl-some '(lambda (x) (if (not (findfile x)) (princ (strcat "\nUnable to find \"" x "\" file.")))) slidefiles) ) ) ( (not (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w")) (princ (apply 'strcat (mapcar (function (lambda (x) (apply 'strcat (mapcar 'chr x)))) '( (116 101 115 116 32 58 32 100 105 97 108 111 103 32) (123 32 108 97 98 101 108 32 61 32 34 73 110 116 101 114 115 101 99 116 105 111 110 115 34 59) (32 32 58 32 98 111 120 101 100 95 99 111 108 117 109 110 32) (32 32 123 32 108 97 98 101 108 32 61 32 34 67 104 111 111 115 101 32 97 99 116 105 111 110 34 59 32 115 112 97 99 101 114 95 49 59) (32 32 32 32 58 32 114 111 119 32) (32 32 32 32 123 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 119 105 100 116 104 32 61 32 116 114 117 101 59 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 104 101 105 103 104 116 32 61 32 116 114 117 101 59 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 32 123 32 107 101 121 32 61 32 34 109 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 123 32 107 101 121 32 61 32 34 116 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 125) (32 32 32 32 58 32 114 111 119 32) (32 32 32 32 123 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 119 105 100 116 104 32 61 32 116 114 117 101 59 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 104 101 105 103 104 116 32 61 32 116 114 117 101 59 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 32 123 32 107 101 121 32 61 32 34 112 115 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 123 32 107 101 121 32 61 32 34 116 107 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 125) (32 32 125) (32 32 115 112 97 99 101 114 95 49 59 32 111 107 95 111 110 108 121 59 32 58 32 116 101 120 116 32 123 32 108 97 98 101 108 32 61 32 34 67 114 101 100 105 116 115 32 116 111 58 32 76 101 101 32 77 97 99 34 59 32 97 108 105 103 110 109 101 110 116 32 61 32 114 105 103 104 116 59 32 125 ) (125) ) ) ) des ) (not (setq des (close des))) (< 0 (setq dch (load_dialog dcl))) ); and ); not (princ "\nUnable to write or load the DCL file.") ) ( (not (new_dialog "test" dch)) (princ "\nUnable to display the dialog") ) ( (progn (mapcar (function (lambda (x) (action_tile x (vl-prin1-to-string '(progn (done_dialog 1) (setq r $key)))))) '("me" "te" "pse" "tk") ) (mapcar (function (lambda ( key sld / w h ) ; (slide_image x1 y1 width height sldname) (setq w (1- (dimx_tile key))) (setq h (1- (dimy_tile key))) (start_image key) (fill_image 0 0 w h 0) (slide_image 0 0 w h sld) (end_image) ; (fill_image ...) might be redundant ; (start_image "me") (slide_image 0 0 (1- (dimx_tile "me")) (1- (dimy_tile "me")) "SlideName.sld") (end_image) ) ) '("me" "te" "pse" "tk") slidefiles ) (action_tile "accept" (vl-prin1-to-string '(progn (princ "\nBye!") (done_dialog 2)))) (/= 1 (setq dcf (start_dialog))) ); progn (princ) ; (princ "\nUser cancelled the dialog.") ) (T (eval (cadr (assoc r L))) ) ); cond (*error* nil) (princ) ); defun ;;--------------------=={ Intersections }==-------------------;; ;; ;; ;; Returns a list of all points of intersection between ;; ;; two objects for the given intersection mode. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2012 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; obj1, obj2 - VLA-Objects ;; ;; mode - acextendoption enum of intersectwith method ;; ;;------------------------------------------------------------;; ;; Returns: List of intersection points, or nil ;; ;;------------------------------------------------------------;; (defun LM:Intersections ( obj1 obj2 mode / l r ) (setq l (vlax-invoke obj1 'intersectwith obj2 mode)) (repeat (/ (length l) 3) (setq r (cons (list (car l) (cadr l) (caddr l)) r) l (cdddr l) ) ) (reverse r) ) ;; Intersections in Set - Lee Mac ;; Returns a list of all points of intersection between all objects in a supplied selection set. ;; sel - [sel] Selection Set (defun LM:intersectionsinset ( sel / id1 id2 ob1 ob2 rtn ) (repeat (setq id1 (sslength sel)) (setq ob1 (vlax-ename->vla-object (ssname sel (setq id1 (1- id1))))) (repeat (setq id2 id1) (setq ob2 (vlax-ename->vla-object (ssname sel (setq id2 (1- id2)))) rtn (cons (LM:intersections ob1 ob2 acextendnone) rtn) ) ) ) (apply 'append (reverse rtn)) ) Quote
Guest Posted May 17, 2017 Posted May 17, 2017 Grrr thank you for the help. can you explain me what is all this numbers? You use any program to do this? (mapcar (function (lambda (x) (apply 'strcat (mapcar 'chr x)))) '( (116 101 115 116 32 58 32 100 105 97 108 111 103 32) (123 32 108 97 98 101 108 32 61 32 34 73 110 116 101 114 115 101 99 116 105 111 110 115 34 59) (32 32 58 32 98 111 120 101 100 95 99 111 108 117 109 110 32) (32 32 123 32 108 97 98 101 108 32 61 32 34 67 104 111 111 115 101 32 97 99 116 105 111 110 34 59 32 115 112 97 99 101 114 95 49 59) (32 32 32 32 58 32 114 111 119 32) (32 32 32 32 123 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 119 105 100 116 104 32 61 32 116 114 117 101 59 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 104 101 105 103 104 116 32 61 32 116 114 117 101 59 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 32 123 32 107 101 121 32 61 32 34 109 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 123 32 107 101 121 32 61 32 34 116 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 125) (32 32 32 32 58 32 114 111 119 32) (32 32 32 32 123 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 119 105 100 116 104 32 61 32 116 114 117 101 59 32 99 104 105 108 100 114 101 110 95 102 105 120 101 100 95 104 101 105 103 104 116 32 61 32 116 114 117 101 59 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 32 123 32 107 101 121 32 61 32 34 112 115 101 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 32 32 58 32 105 109 97 103 101 95 98 117 116 116 111 110 32 123 32 107 101 121 32 61 32 34 116 107 34 59 32 104 101 105 103 104 116 32 61 32 49 50 59 32 119 105 100 116 104 32 61 32 51 50 59 32 99 111 108 111 114 32 61 32 103 114 97 112 104 105 99 115 95 98 97 99 107 103 114 111 117 110 100 59 32 125 ) (32 32 32 32 125) (32 32 125) (32 32 115 112 97 99 101 114 95 49 59 32 111 107 95 111 110 108 121 59 32 58 32 116 101 120 116 32 123 32 108 97 98 101 108 32 61 32 34 67 114 101 100 105 116 115 32 116 111 58 32 76 101 101 32 77 97 99 34 59 32 97 108 105 103 110 109 101 110 116 32 61 32 114 105 103 104 116 59 32 125 ) (125) ) Quote
Grrr Posted May 17, 2017 Posted May 17, 2017 Thats just the DCL code - hardcoded a bit - to prevent easy removal of Lee Mac's nickname. Since all or almost all of the subfunctions provided and the overall dcl-on-the-fly technique were demonstrated by him, so practically his presence is in ~90% of the code. A bit of appreciation would be nice (instead of assembling his codes posted in different threads and claiming for authority). Quote
Guest Posted May 17, 2017 Posted May 17, 2017 I din't have problem with the LeeMac nickname just ask how i can do it.is any command throu autocad visual lisp or i need another program. Is any program can help me with the dcl , to draw the form i need and give me the code? (like visual basic?) Quote
BIGAL Posted May 18, 2017 Posted May 18, 2017 (edited) I am lucky and have a copy of Autocad release 12 (not 2012) help manual and it has all the sample code for doing dcl's this is still available in the Autocad Help but you have to find it. Once you get an idea of what you want its not that hard, I have dcl's with sub dcls yes you can call another dcl level, they have stuff like sliders so you can drag for answers required. Start here https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-AutoLISP/files/GUID-E10AFB89-89BF-4616-819A-439BAEAAD0B9-htm.html If you post a dwg of what you want the dcl to look like we may be able to help. Edited May 18, 2017 by BIGAL Quote
Guest Posted May 18, 2017 Posted May 18, 2017 How i hardcoded a DCL code ? is any program to do this? Quote
Guest Posted May 18, 2017 Posted May 18, 2017 Hi Grrr.I want to ask you a question.If i understand all the DCL file is hardcoded. If i want to add some other intersections in the same project and have 4 lines and 5 rows is not possible ? Quote
BIGAL Posted May 18, 2017 Posted May 18, 2017 Yes I have default dcl for slides 2x2 3x2 4x4 etc its just a case of adding more rows and columns. In the example below each image has a key ID like "33sq1" the images are supplied as a list ("slide1" "slide2" ...) via a lisp using a 33sq+x where x starts at 1 and you repeat to populate the images. This was done as a library routine so can work with any program returning some value for the square picked. I will try to find the correct code to call the dcl its at home. // DD3x3 dialogue. Used by DD3x3.lsp. // By Alan H 1990. dd3x3 : dialog { label = "Please choose item"; : column { : row { : image_button { key = "33sq1"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq2"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq3"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } } : row { : image_button { key = "33sq4"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq5"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq6"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } } : row { : image_button { key = "33sq7"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq8"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } : image_button { key = "33sq9"; width = 10; aspect_ratio = 1.0; color = 0; allow_accept = true; } } } ok_cancel; } Quote
