jmos4 Posted May 19, 2017 Posted May 19, 2017 Hi, I have a vertical dimension and the space between leader forces the text out, but it goes to the right and I want the text to flip out to the left is there a flip command? see below: Quote
jmos4 Posted May 19, 2017 Author Posted May 19, 2017 Sorry the picture didn't come out ---- text l V -------- -------- A l I want this arrangement: text ---- l V -------- -------- A l regards, Quote
Ski_Me Posted May 22, 2017 Posted May 22, 2017 I think you can do this in your dimension style manager. Just got to the dimension tab and edit your dimension style. Quote
CyberAngel Posted May 22, 2017 Posted May 22, 2017 Right-click on the text, pick "move with leader," drag the text far enough to flip the leader. Once the leader flips, you can move the text backward somewhat before the leader flips again. If that doesn't work, you may be able to adjust the Text and Fit settings for your dimension to get what you want. As a last resort, you could change the dim style, but that will affect all dimensions using that style. Consider making a copy of the current style and applying it to this situation. Quote
