Organic Posted May 30, 2017 Posted May 30, 2017 (edited) Hi Lee & others, With regards to Lee Mac's code from https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/change-all-to-0-layer-by-layer-including-block-and-block-in/td-p/5376995 (defun c:blkto0 ( / idx lst sel ) (if (setq sel (ssget '((0 . "INSERT")))) (repeat (setq idx (sslength sel)) (block->0 (cdr (assoc 2 (entget (ssname sel (setq idx (1- idx))))))) ) ) (command "_.regen") (princ) ) (defun block->0 ( blk / ent enx ) (cond ( (member blk lst)) ( (setq ent (tblobjname "block" blk)) (while (setq ent (entnext ent)) (entmod (subst-append 8 "0" (subst-append 62 0 (setq enx (entget ent))))) (if (= "INSERT" (cdr (assoc 0 enx))) (block->0 (cdr (assoc 2 enx))) ) ) (setq lst (cons blk lst)) ) ) ) (defun subst-append ( key val lst / itm ) (if (setq itm (assoc key lst)) (subst (cons key val) itm lst) (append lst (list (cons key val))) ) ) The above works excellent when drawings are set up well although unfortunately a lot of architectural ones are not... Is it possible to modify this so it changes all blocks/nested blocks to have colour set to 'by block' as per the above although so that the blocks/nested blocks all keep their original layers (i.e. not go to layer 0 etc)? Thanks Edited May 30, 2017 by Organic Quote
Organic Posted May 30, 2017 Author Posted May 30, 2017 I worked it out Removing the layer change part (subst-append 8 "0" and its close bracket done it! (defun c:blkto0 ( / idx lst sel ) (if (setq sel (ssget '((0 . "INSERT")))) (repeat (setq idx (sslength sel)) (block->0 (cdr (assoc 2 (entget (ssname sel (setq idx (1- idx))))))) ) ) (command "_.regen") (princ) ) (defun block->0 ( blk / ent enx ) (cond ( (member blk lst)) ( (setq ent (tblobjname "block" blk)) (while (setq ent (entnext ent)) (entmod (subst-append 62 0 (setq enx (entget ent)))) (if (= "INSERT" (cdr (assoc 0 enx))) (block->0 (cdr (assoc 2 enx))) ) ) (setq lst (cons blk lst)) ) ) ) (defun subst-append ( key val lst / itm ) Thanks for the excellent lisp. Quote
Lee Mac Posted May 30, 2017 Posted May 30, 2017 Your modification is correct - well done. Here is the code with appropriate indentation: (defun c:blkto0 ( / idx lst sel ) (if (setq sel (ssget '((0 . "INSERT")))) (repeat (setq idx (sslength sel)) (block->0 (cdr (assoc 2 (entget (ssname sel (setq idx (1- idx))))))) ) ) (command "_.regen") (princ) ) (defun block->0 ( blk / ent enx ) (cond ( (member blk lst)) ( (setq ent (tblobjname "block" blk)) (while (setq ent (entnext ent)) (entmod (subst-append 62 0 (setq enx (entget ent)))) (if (= "INSERT" (cdr (assoc 0 enx))) (block->0 (cdr (assoc 2 enx))) ) ) (setq lst (cons blk lst)) ) ) ) (defun subst-append ( key val lst / itm ) (if (setq itm (assoc key lst)) (subst (cons key val) itm lst) (append lst (list (cons key val))) ) ) I'm pleased that you find the program useful! Quote
