guitarguy1685 Posted June 8, 2017 Posted June 8, 2017 I'm posting here because I think this is more of a management questions than a lisp question. My question is this; if you have a suite of lisps, do you give the command names "shortcut" names or full descriptive names? For example, I have a command that I call "COPYRADIAL". in my lisp that's what you use to call it. (defun C:COPYRADIAL (/)...etc Some people might just use (defun c:CR (/)...etc I don't use a shortcut because I don't want to inadvertently override a users personal pgp customizations, or an ACAD shortcut I just missed. The only downside is some users are not savvy enough to figure out how to customize their shortcuts. (i know, i know). How do you CAD managers approach this? Quote
BIGAL Posted June 8, 2017 Posted June 8, 2017 CPR cardiopulmonary resuscitation or copy radial. Just check acad.pgp 1st. Quote
Commandobill Posted July 28, 2017 Posted July 28, 2017 With autocad's autocomplete function, lately, I have had longer command names, since it's easy to use once you've typed them in a couple times. 1 Quote
tricon77 Posted June 28, 2024 Posted June 28, 2024 I have comprise a very long lisp file for all of my shortcuts. I saw someone's code that use a ":" for a prefix to a command. This idea made me group my sub-commands. For me, I use colon followed by a thing to launch a text based menu to trigger other commands. I just have one menu to focus on my workflow. This way out can use long function names. I took a class in OOP so my function are similar to that. Also this way a user can create a function to call another function to just shorten the name. Quote
Pault43 Posted February 10 Posted February 10 Same here, no shortcuts. I name according to what it does, and the name is the command. Most of the shortcuts I use are for specialized situations. I'm Civil so, I'm not continually using lsp's back to back to back. Quote
BIGAL Posted February 10 Posted February 10 If you have lots of lisps then why not have a custom menu. For Civ3D I made a custom menu that had CIV3D commands in it so when working in Drafting workspace those Civ3D commands were available. I also made a custom tool bar, it replaced the change surfaces via the Tool space as the icons were say display 0.5 Contours, turn off surface displays etc. Yes its available just ask. Quote
CivilTechSource Posted 2 hours ago Posted 2 hours ago I added a prefix to all my lisp e.g. LE-XXXx. So when I type LE- all my lisps load and can still have the full name LE-SetMyTopo. I try to categorise lisps based on function. LE-SetMyXXX, LE-FixMyXXX, LE-Draw, LE-ModXXXX Quote
