I am looking for a way to automate my drawing plotting.
Every drawing I make has the same 4 layouts, with the following names: CP1, CU1, 3L1, 3L2. I always need to plot three documents with the following conventions.
[Drawing Name]-CP.pdf This contains just the page CP1.
[Drawing Name]-CU.pdf This contains just the page CU1.
[Drawing Name]-3L.pdf This contains page 3L1 and 3L2.
The plots for these drawings should always be saved one level higher in my file path. I.e. the path for the AutoCad file is /.../Engineering Drawings/AutoCAD/ and the pdfs should be saved to /.../Engineering Drawings/.
Can anyone suggest the right path to head down to automate this process?
Cheers,
Dan
Here is a start this is the latest version will do what you want it plots a range so you can do layout 1 or 2-3 etc. You need to download Ghostscript seperately as it combines the pdf's into 1.
;Plots layouts by range
; By Alan H Feb 2014
(defun AH:pltlays ( / val1 val2 plotnames dwgname lendwg pdfname lay numlay numend dwgpre)
(SETVAR "PDMODE" 0)
(setvar "plottransparencyoverride" 2)
(setvar "fillmode" 1)
(setvar "textfill" 1)
(setq plotnames '())
; check that pdf directory exists
(setq dwgpre (strcat (getvar "dwgprefix") "\pdf"))
(if (= (vl-file-directory-p dwgpre) nil)
(vl-mkdir dwgpre)
(SETQ LAYOUTS (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
(SETQ COUNT (- (VLA-GET-COUNT LAYOUTS) 1))
(if (not AH:getval2) (load "getvals3"))
(ah:getval2 "Enter start tab number" 6 4 "1" "Enter end tab number" 6 4 (RTOS COUNT 2 0))
(setq numlay (ATOI val1))
(setq numend (ATOI val2))
(setq len (+ (- numend numlay) 1))
(setq dwgname (GETVAR "dwgname"))
(setq lendwg (strlen dwgname))
(setq dwgname (substr dwgname 1 (- lendwg 4)))
(repeat len
(vlax-for lay LAYOUTS
(if (= numlay (vla-get-taborder lay))
 (setvar "ctab" (vla-get-name lay))
) ; if
(setq pdfname (strcat dwgpre "\\" dwgname "-" (getvar "ctab") ".pdf" ))
) ; for
(setvar "PLOTTRANSPARENCYOVERRIDE" 2)
   (COMMAND "-PLOT"  "Y"  "" "dwg to Pdf"
       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
       "y" "Designlasercolour.ctb" "Y" "n" "n" "n" pdfName "N" "y"
(setq numlay (+ numlay 1))
(setq plotnames (cons pdfname plotnames))
) ; end repeat
(setq trgfile (strcat (getvar "dwgprefix") "pdf\\" dwgname "-D" val1 "-D" val2 ".pdf"))
(setq plotnames (reverse plotnames))
(IF (= (length plotnames) 1)
(if (not combinepdf)(load "mergepdfs"))
(combinepdf gsExe plotnames trgFile )
) ; defun
(AH:pltlays)
;MergePdfs
;Merges multiple pdf (or eps) files into one
;Requires the installatoion of Ghostscript
; make a batch file ?
;gs -sDEVICE=pdfwrite \
;    -dNOPAUSE -dBATCH -dSAFER \
;    -sOutputFile=combined.pdf \
;    first.pdf \
;    second.pdf \
;    third.pdf [...]
;Ghostscript ([url]http://www.ghostscript.com/[/url]) can be used to combine PDFs.
; Something like this should work: by Roy_043
(defun KGA_String_Join (strLst delim)
(if strLst
(apply
'strcat
(cons
(car strLst)
(mapcar '(lambda (a) (strcat delim a)) (cdr strLst))
; (CombinePdf
 (setq gsexe "C:\\Program Files\\gs\\gs9.19\\bin\\gswin64c.exe")
; (setq srcFilelst  '("D:\\Tmp\\A.pdf" "D:\\Tmp\\B.pdf"))
; (setq trgfile "C:\\Acadtemp\\Total.pdf")
; Note: Existing trgFile will be overwritten.
(defun CombinePdf (gsExe srcFileLst trgFile)
(startapp
(strcat
gsExe " "
"-sDEVICE=pdfwrite -dBATCH -dNOPAUSE -dQUIET  "
"-sOutputFile=\"" trgFile "\" "
"\"" (KGA_String_Join srcFileLst "\" \"") "\""
and this
; Input  Dialog box with variable title
; multiple lines of dcl input supported
; add extra lines if required by copying code defun
; By Alan H 2015
(vl-load-com)
; 1 line dcl
; sample code (ah:getval1 "Line 1" 5 4)
(defun AH:getval1 (title width limit def1 / fo fname)
; you can hard code a directory if you like for dcl file
(setq fo (open (setq fname "c:\\acadtemp\\getval.dcl") "w"))
(write-line "ddgetval : dialog {" fo)
(write-line " : row {" fo)
(write-line ": edit_box {" fo)
(write-line (strcat "    key = "  (chr 34) "key1" (chr 34) ";") fo)
(write-line  (strcat " label = "  (chr 34) title (chr 34) ";"  )   fo)
; these can be replaced with shorter value etc
(write-line (strcat "     edit_width = " (rtos width 2 0) ";" ) fo)
(write-line (strcat "     edit_limit = " (rtos limit 2 0) ";" ) fo)
(write-line "   is_enabled = true;" fo)
(write-line "    }" fo)
(write-line "ok_only;}" fo)
(close fo)
(setq dcl_id (load_dialog  fname))
; pt is a list 2 numbs -1 -1 centre ('(20 20))
;(not (new_dialog "test" dch "" *screenpoint*))
(if (not (new_dialog "ddgetval" dcl_id))
(exit))
(set_tile "key1" (setq val1 def1))
(action_tile "key1" "(setq val1 $value)")
(mode_tile "key1" 3)
(start_dialog)
(done_dialog)
(unload_dialog dcl_id)
; returns the value of val1 as a string
(vl-file-delete fname)
) ; defungetval1
; 2 line dcl
; sample code (ah:getval2 "Line 1" 5 4 "Line2" 8 7)
(defun AH:getval2 (title1 width1 limit1 def1 title2 width2 limit2 def2 / fo fname)
(write-line "ddgetval2 : dialog {" fo)
(write-line " : column {" fo)
(write-line  (strcat " label = "  (chr 34) title1 (chr 34) ";" ) fo)
(write-line (strcat "     edit_width = " (rtos width1 2 0) ";" ) fo)
(write-line (strcat "     edit_limit = " (rtos limit1 2 0) ";" ) fo)
(write-line "   is_enabled = true ;" fo)
(write-line "spacer_1 ;" fo)
(write-line (strcat "    key = " (chr 34) "key2" (chr 34) ";") fo)
(write-line (strcat " label = "  (chr 34) title2 (chr 34) ";"  ) fo)
(write-line (strcat "     edit_width = " (rtos width2 2 0) ";" ) fo)
(write-line (strcat "     edit_limit = " (rtos limit2 2 0) ";" ) fo)
(close fo)
; code part
(if (not (new_dialog "ddgetval2" dcl_id))
(exit))
(mode_tile "key2" 3)
(set_tile "key2" (setq val2 def2))
(action_tile "key2" "(setq val2 $value)")
(start_dialog)
(done_dialog)
; returns the value of val1 and val2 as strings
) ; defungetval2
; 3 line dcl
; sample code (ah:getval3 "Line 1" 5 4 "0.9" "Line 2" 8 7 "wow" "Line 3" 6 4 "123")
(defun AH:getval3 (title1 width1 limit1 def1 title2 width2 limit2 def2 title3 width3 limit3 def3 / fo fname)
(write-line "ddgetval3 : dialog {" fo)
(write-line (strcat "    key = " (chr 34) "key3" (chr 34) ";") fo)
(write-line (strcat " label = "  (chr 34) title3 (chr 34) ";"  ) fo)
(write-line (strcat "     edit_width = " (rtos width3 2 0) ";" ) fo)
(write-line (strcat "     edit_limit = " (rtos limit3 2 0) ";" ) fo)
(close fo)
; code part
(if (not (new_dialog "ddgetval3" dcl_id))
(exit))
(mode_tile "key3" 3)
(set_tile "key3" (setq val3 def3))
(action_tile "key3" "(setq val3 $value)")
(start_dialog)
(done_dialog)
; returns the value of val1 val2 and val3 as strings
) ; defungetval3
Edited by BIGAL
