calculating flat pattern dimension
Hello all,
What I am trying to do is calculate the correct length of my flat pattern part, so it will match outside dimensions required after bending. Will AutoCAD calculate this formula for me depending on my material thickness and bend radius?
Thank you,
JLovgren
Stevsmith,
Thank you for the great link! But are you telling me that AutoCAD will not calculate bend dimensions into a flat pattern dimension?
Im afraid not my friend.
Simply because AutoCAD is not a parametric modeler.
You would require either, Solidworks, AutoDesk Inventor or Radan CAD/CAM.
Although I heard through the grapevine that AutoCAD 2010 will have this....
To be honest a quick cheat with sheetmetal bends are to use the outside dimensions to addup the overall length.
Unless you work to high tollerance.
(fabricator to trade, so I know the cheats.)
Take a look at AutoPOL, I am not selling it :)
However, I do sell Alibre Design that include a sheet metal module with unfolding.
