Gday all,
Just wondering, with the express tools, if there was a way to convert multiple dtext to mtext without it all combining to the one mtext.
Is there a lisp or system setting??
Any help would be greatly appreciated.
Cheers
Dean07
Found this at Autodesk forum, posted by Matt Stachoni:
Re: convert dtext to mtext in entire drawing
On Mon, 19 Mar 2007 20:06:16 +0000, mharrison wrote:
>i have drawings that need all of the dtext converted to mtext. in the past i have been selecting each dtext text individually and then converting it over to mtext using my express command. is there a way to convert the entire drawing over to Mtext?
Not using the OOTB tool (which results in a single MText object if you select
multipe entities), but you can do one of two things:
1. Use MULTIPLE TXT2MTXT to run the command over again. Kinda kludgy.
2. Add this little wrapper command for the TXT2MTXT tool to your acaddoc.lsp
file and it will work:
(defun c:T2M (/ i ss e)
(setq i -1)
(if (setq ss (ssget '((0 . "TEXT"))))
(while (setq e (ssname ss (setq i (1+ i))))
(command "._txt2mtxt" e "")
If you're not familiar with Lisp, see the FAQ section on this site. Basically create a text file with a ".lsp" extension, containing the following. Drag n drop in AutoCAD, type T2M to start.
  (setq i -1)
Thanks very much for that. Exactly what I was looking for.
  • 5 years later...
Is there any way of getting this one to work so it keeps in the text in it's original location?
