Thomas Baxter Posted June 29, 2017 Posted June 29, 2017 when i open a two port view port the second port i isometric? Quote
Ski_Me Posted June 29, 2017 Posted June 29, 2017 I think that's the default but you can change it. In the upper left hand corner of the viewport there is a drop down list when you click on isometric. You can also click on the controls on the left side which is the box that says top, left, right, front, back. Just click on top and the view will change to a top down view. Quote
steven-g Posted June 29, 2017 Posted June 29, 2017 Someone at Autodesk has a sense of humour, the default behaviour in full autocad when using the ribbon to create multiple viewports, is to create them all in plan view, but for LT the default is to use the 3D isometric view. Quote
Dana W Posted June 30, 2017 Posted June 30, 2017 Someone at Autodesk has a sense of humour, the default behaviour in full autocad when using the ribbon to create multiple viewports, is to create them all in plan view, but for LT the default is to use the 3D isometric view.Yeah, ever seen inside of their company? Full of Hipsters. They think ironic humor is the best thing since peanut butter and chocolate. Quote
