Serhan_BAKIR Posted July 2, 2017 Posted July 2, 2017 Hi there, I'm trying to modify a diametric dimension which has a block reference that makes up its picture, and turn it to its native view. If you can kindly check the attached drawing, you can see that there is a sample dimension exported from Revit, what I achieved so far and the desired result side by side. With the following code I managed to loop through the dimension "block", find the mtext object and its insertion point. Then I modify the "dimension"s textposition with the insertion point at hand but somehow the justification of text changes and I can not get the desired orientation. I'll really appreciate your helps to make it as close as to the original view. Thanks! (defun c:fixdim() (setq dim (car(entsel))) (setq dim-obj (vlax-ename->vla-object dim)) (setq dimtxtloc (get-dimblktxtloc dim)) (setq s-array (vlax-make-safearray vlax-vbdouble '(0 . 2))) (vla-put-textposition dim-obj (vlax-safearray-fill s-array dimtxtloc)) ) (defun get-dimblktxtloc (dim-ename) (setq dim-entity (vl-catch-all-apply 'entget (list dim-ename))) (cond ((not (vl-catch-all-error-p dim-entity)) (setq dim-blockname (cdr (assoc 2 dim-entity))) (setq blk-object (get-dimblkobj dim-blockname)) (cond ((not (vl-catch-all-error-p blk-object)) (vlax-for subobj blk-object (cond ((= (vla-get-objectname subobj) "AcDbMText") (setq blk-txtloc (safearray-value (vlax-variant-value (vla-get-insertionpoint subobj)))) ) ) ) ) ) ) ) blk-txtloc ) (defun get-dimblkobj (blockname) (vl-catch-all-apply 'vla-item (list (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) blockname)) ) Dimension Picture.dwg Quote
