hi
i wanna convert a 2d servy plan into a 3d plan,
meaning that ill provide all Z data according to the textual information.
designing a house, i need the interior rectangle stay in a fixed level while the outer recatngle is a to multiple level points.
i cant find a way to tackle it
please help
THanks
SHay
It starts with a contour map.
Remark....I have the servy map. It without z data
Sent from my MOBIX M6 using Tapatalk
The most common is yes its 3d. All you have is this text as Z levels or contours again with a Z value of Zero. What do you do ?
1 Move the contour to true elevation. move 0,0,0 0,0,Z
2 Various routines but bottom line they create a point with a z value equal to text value.
3 Make a 3d surface. And away you go.
; converts text to a point with xyz
; z value equal to text
; by Alan H Nov 99
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(while (not (setq ss (ssget))))
(command "layer" "new" "txthts" "")
(setvar "clayer" "txthts")
(setvar "pdsize" 3)
(setvar "pdmode" 35)
(while (setq en (ssname ss 0))
    ; Entity type
    (setq entyp (cdr (assoc 0 (entget en))))
   (if (= entyp "TEXT")
   (setq xyz (cdr (assoc 10 (entget en))))
   (setq txtht (cdr (assoc 1 (entget en))))
(princ txtht)
   (setq txtz (atof txtht))
   (setq ptxyz (list (car xyz)(cadr xyz) txtz))
   (command "point" ptxyz)
   ; Delete each measured entity from set
   (ssdel en ss)
;end while
(setvar "osmode" oldsnap)
You said you had the "Z" data in text form. That implies you have spot elevations. My suggestion would be to create contours using the spot elevations through interpolation then move the contours to their true elevation.
Please post in the appropriate forums. I have moved nearly all of the threads you have started. This thread had nothing to do with Cad Mangement.
Discussion of CAD Management, network issues, drawing standards, layer naming, backup strategies, training concepts…
