As we have the UPDATE command in the DIMENSIONS menù, i would like to have a command that restore ALL the properties of selected MLs to the current one.
Is it possible through a lisp??
Thanks for the help.
Bix
Welcome to CADTutor bixcad. :)
This could be very easily done with Properties.
Select all of the Multileaders, then in Properties enter the Multileader Style name which you want to assign to all of them.
Done. :|
unfortunately if i've previously changed some properties of some ML (f.e. arrows dimensions or text height) when i change the style in the Properties the values of the changed properties does not changes to the default ones set in the ML style settings...
If there are only about 3 things you have changed, just enter the values you want used universally for all of the multileaders.
Sounds like you may have changed more though.
The real problem is that once you have changed a value from Properties if I change the style they don't pick that change of the style anymore... so quite unuseful if i have a ton of ML in the same file.
That's the reason why i need and UPDATE command that resume all the values to the Style's defaults. (as for the Dims)
