Which parameter controls the number/width of the lines displayed when you turn fill off on donuts?
Welcome to CAD Tutor!
As I suspected, the density of those lines is controlled by the VIEWRES command. Keep in mind that this setting only affects the current viewport.
Thank you. The Viewres command was exactly what I was looking for.
Trying to learn AutoCAD is both rewarding and frustrating as a beginner due to both the complexity and power of the tool. A lot of the times it is difficult to clearly ask a question. Thank you for taking the time to translate my normal speech to the AutoCAD world and answer the question.
Stick with it. Frustration is a part of learning anything. It gets easier.
