Jeremy Cabrera Posted July 10, 2017 Posted July 10, 2017 Dear Autolisp expert, I would like please to help me creating subroutines for a mining project. The purpose of these routines will allow creating a room and pillar underground mining design according to the following steps: 1.- Determine the limits of the project by clicking the upper left and lower right corners. 2.- Create a grid inside the limits. The grid must be created using the attached example. 3.- Once the grid is done create an option to rotate the entire grid using the upper left corner as pivot. 4.- Create an option to lower or raise the entire grid elevation. 4.- Create an option for loading a closed polyline. 5.- Trim the grid with the closed polyline and erase everything outside the polyline. Thank you, I will appreciate your rapid response. Regards, Jeremy Grilla 01.dwg Quote
rkmcswain Posted July 10, 2017 Posted July 10, 2017 All of this can be found in Carlson Software. Quote
ronjonp Posted July 10, 2017 Posted July 10, 2017 You could "cheat" and use an array, then make it a block and xclip the area wanted .. EXAMPLE. Quote
Jeremy Cabrera Posted July 10, 2017 Author Posted July 10, 2017 I reviewed what they has to offer and I could not find what I am looking for...thanks anyways ...maybe you have some other sites I can navigate.. Quote
