I have a drawing with 2d polylines which when selected it highlights thousands of I assume points, how can I change the polyline to have minimal points. These are slowing my machine to a snail's pace.
all help appreciated.
Regards,
Keith
There is a lisp called "weed" I have not used it that helps to remove vertices.
Just cut the line in pieces or upgrade your pc. If something like a lot of vertices slows down the drawing proces there must be something else wrong in the drawing.
Copy the line to a empty drawing and see if it still slows down the computer. If all is fine then it's something else (perhaps the background image).
