hi
for some reasom
in the CUI
1.im loading a partial costume file
2.im loading the lisp file
3.Keybord Shortcut > New > Overriden Keybord Shortcut
notes:
using acad 2010
it seems like autocad ignore the defined combination i declare, instead, it evaluated as is
any idea?
Assuming you're talking about 'Keyboard Shortcuts' → 'Temporary Override Keys' the ones in the Main CUIX file will take precedence.
i tried to set it in the main CUI (Shift + Key)
but Shift + Key wont even trigger any command
First what's the macro you want to assign?
'Keyboard Shortcuts' → 'Shortcut Keys' which can be assigned to commands you use frequently are very different than 'Keyboard Shortcuts' → 'Temporary Override Keys' which are generally used while a command is in progress to toggle an option. While Shift+Key works as a 'Temporary Override Key' for most keys Shift+letters would put capital letters to the command line when entered otherwise.
The Command Alias Editor is an option as well.
