samifox Posted July 26, 2017 Posted July 26, 2017 hi is there a way to disable the Edit in-place dialog box? (the one that popup when you enter to that isolation state and asking about opening nested blocks) Thanks Quote
SLW210 Posted July 26, 2017 Posted July 26, 2017 -REFEDIT should do it if you just want to suppress the dialog box for command line version. If you want to disable a command For disabling a required command use the "_UNDEFINE" command followed by name of the undefined command. Quote
