Deodar311 Posted July 27, 2017 Posted July 27, 2017 Whenever I try to draw a line, arc, circle, etc. the line is a dark green color. Once the line is drawn it reverts to the correct color (typically set as Bylayer). When color is set ByLayer in the Properties box and I start to draw, the lines appear dark green, however when the color is set to any other color and I begin drawing the lines appear in that color (as it should be). Is there a setting I'm missing? It's very weird (and hard to see)! When I first installed AutoCAD 2018, I believe the colors were working properly. Any advice would be greatly appreciated! Thanks! Quote
ReMark Posted July 27, 2017 Posted July 27, 2017 Did you try shutting down AutoCAD then restarting it? Does this happen in just one drawing or every drawing you work in? Quote
Deodar311 Posted July 27, 2017 Author Posted July 27, 2017 I did restart AutoCAD and that didn't fix it, but I think I may have figured out the problem. I need to reboot my computer. While playing a game yesterday I received an error about the windows color scheme and having too/not enough many colors, blah, blah blah. I'm willing to bet that has something to do with it. I will reboot and let everyone know if that seems to solve my problem. Thanks ReMark. Quote
Deodar311 Posted July 27, 2017 Author Posted July 27, 2017 Unfortunately rebooting the computer did not help. The reason it worked earlier is because the color was manually set in the properties box. When the color is set back to "ByLayer", drawing lines, arcs, etc, went back to dark green. Is there some setting in Options/drafting/colors, that could be set?? I re"migrated" my setting from AutoCAD 2016, but that didn't help either. I'm totally stumped. Quote
Deodar311 Posted July 27, 2017 Author Posted July 27, 2017 Sorry about that. After a little trial and error, it seems the error comes from a certain client. Drawings from other clients seem to behave properly. Quote
ReMark Posted July 28, 2017 Posted July 28, 2017 And what program did that client use to create the drawing he eventually passed on to you? Was it Microstation? Quote
Deodar311 Posted August 8, 2017 Author Posted August 8, 2017 My client uses on older version of Autocad. It appears they are still using Autocad 2000. The problems only seem to occur with this client. I suppose this is the problem? Although the problem is not resolved, I will simply ignore the issue. Thanks for your help ReMark! Quote
steven-g Posted August 9, 2017 Posted August 9, 2017 You could post a dwg file here, to see if someone can spot a problem in the file Quote
Deodar311 Posted September 11, 2017 Author Posted September 11, 2017 I realize this topic is slightly old, but I wanted to update it in case other people had similar problems. In short I believe it was the graphics driver. When I disabled hardware acceleration, the lines/arc/etc. went back to their original colors. Just to be clear, the problem occurred when I started drawing any element. The color of the element (line, arc, circle, etc), would not be the color of the layer. Sometimes the color would be very dark, but currently it's white. I am using a AMD R9 390X video card with the latest Radeon drivers. This has not been a problem in the past, so it's either the drivers have changed or Autocad 2018 doesn't work well with this card/driver. Hopefully this will help someone. Thanks Quote
ReMark Posted September 11, 2017 Posted September 11, 2017 And sometimes it is due to the fact that the user, being somewhat new to AutoCAD, overrides the ByLayer setting for color. Quote
