Copy/ increment text to a coordinates list
Hi Guys,
I have a list of 400+ coordinates and I would like to use them to label text starting from 1, and each other coordinate position will be the flowing number.
If I copy a circle (center point), and pasted all the coordinates in at once (copied from excel) into the command bar then it would place the circle at all of the coordinates. Is there a way to do this with text but having it numbering the text from 1 and upwards numerically?
Many thanks,
Texaspete
What is the list?
Is this an Excel / CSV or something? In what order are the coordinates?
Your question is possible relatively easy.. But we need all the info. :-)
In excel there is a command called concatenate it joins cells so just do the same as the circle stuff but with "TEXT x,y num where you get the num part from a column.
=concatenate("Text " b1,",",c1," "," ",a1) Text x,y num your number is in column "A"
I tried this but i the numbers do not update in AutoCAD
You mean this?
Command: CADTUTOR
Places a text on the coordinate, with the given pointnumber?
(defun C:CADTUTOR ( / )
(if (and (setq file (getfiled "\nSelect file... " "Desktop" "xlsx" 16))(setq data (GetExcel file nil nil)))
		(if (/= (getvar "WORLDUCS") 1)(command "UCS" "WORLD"))
		(foreach line data
			(if (and (/= (nth 0 line) "No.")(/= (nth 1 line) "Coords"))
					(setq number (nth 0 line))
					(setq coordinates (nth 1 line))
					(setq coordX (substr coordinates 1 (vl-string-position (ascii ",") coordinates 0 t)))
					(setq coordY (substr coordinates (+ 2 (vl-string-position (ascii ",") coordinates 0 t))))
					(command "_TEXT" (strcat coordx "," coordy) "" number)
					(princ "First line is a header.")
		(princ "No file selected.")
; Program Name: GetExcel.lsp [GetExcel R4]
; Created By:   Terry Miller (Email: terrycadd@yahoo.com)
;               (URL: http://web2.airmail.net/terrycad)
; Date Created: 9-20-03
; Function:     Several functions to get and put values into Excel cells.
; Revision History
; Rev  By     Date    Description
; 1    TM   9-20-03   Initial version
; 2    TM   8-20-07   Rewrote GetExcel.lsp and added several new sub-functions
;                     including ColumnRow, Alpha2Number and Number2Alpha written
;                     by Gilles Chanteau from Marseille, France.
; 3    TM   12-1-07   Added several sub-functions written by Gilles Chanteau
;                     including Cell-p, Row+n, and Column+n. Also added his
;                     revision of the PutCell function.
; 4    GC   9-20-08   Revised the GetExcel argument MaxRange$ to accept a nil
;                     and get the current region from cell A1.
; Overview of Main functions
; GetExcel - Stores the values from an Excel spreadsheet into *ExcelData@ list
;   Syntax:  (GetExcel ExcelFile$ SheetName$ MaxRange$)
;   Example: (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30")
; GetCell - Returns the cell value from the *ExcelData@ list
;   Syntax:  (GetCell Cell$)
;   Example: (GetCell "H15")
; Function example of usage:
; (defun c:Get-Example ()
;   (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30");<-- Edit Filename.xls
;   (GetCell "H21");Or you can just use the global *ExcelData@ list
; );defun
; OpenExcel - Opens an Excel spreadsheet
;   Syntax:  (OpenExcel ExcelFile$ SheetName$ Visible)
;   Example: (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil)
; PutCell - Put values into Excel cells
;   Syntax:  (PutCell StartCell$ Data$) or (PutCell StartCell$ DataList@)
;   Example: (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""))
; CloseExcel - Closes Excel session
;   Syntax:  (CloseExcel ExcelFile$)
;   Example: (CloseExcel "C:\\Folder\\Filename.xls")
; (defun c:Put-Example ()
;   (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil);<-- Edit Filename.xls
;   (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""));Repeat as required
;   (CloseExcel "C:\\Folder\\Filename.xls");<-- Edit Filename.xls
;   (princ)
; );defun
; Note: Review the conditions of each argument in the function headings
; Arguments: 3
;   ExcelFile$ = Path and filename
;   SheetName$ = Sheet name or nil for not specified
;   MaxRange$ = Maximum cell ID range to include or nil to get the current region from cell A1
; Syntax examples:
; (GetExcel "C:\\Temp\\Temp.xls" "Sheet1" "E19") = Open C:\Temp\Temp.xls on Sheet1 and read up to cell E19
; (GetExcel "C:\\Temp\\Temp.xls" nil "XYZ123") = Open C:\Temp\Temp.xls on current sheet and read up to cell XYZ123
(defun GetExcel (ExcelFile$ SheetName$ MaxRange$ / Column# ColumnRow@ Data@ ExcelRange^
 ExcelValue ExcelValue ExcelVariant^ MaxColumn# MaxRow# Range$ Row# Worksheet)
 (if (= (type ExcelFile$) 'STR)
   (if (not (findfile ExcelFile$))
       (alert (strcat "Excel file " ExcelFile$ " not found."))
       (exit)
     );progn
   );if
     (alert "Excel file not specified.")
     (exit)
   );progn
 );if
 (gc)
 (if (setq *ExcelApp% (vlax-get-object "Excel.Application"))
     ;(alert "Close all Excel spreadsheets to continue!")
     (vlax-release-object *ExcelApp%)(gc)
   );progn
 );if
 (setq ExcelFile$ (findfile ExcelFile$))
 (setq *ExcelApp% (vlax-get-or-create-object "Excel.Application"))
 (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Open ExcelFile$)
 (if SheetName$
   (vlax-for Worksheet (vlax-get-property *ExcelApp% "Sheets")
     (if (= (vlax-get-property Worksheet "Name") SheetName$)
       (vlax-invoke-method Worksheet "Activate")
     );if
   );vlax-for
 );if
 (if MaxRange$
     (setq ColumnRow@ (ColumnRow MaxRange$))
     (setq MaxColumn# (nth 0 ColumnRow@))
     (setq MaxRow# (nth 1 ColumnRow@))
   );progn
     (setq CurRegion (vlax-get-property (vlax-get-property
       (vlax-get-property *ExcelApp% "ActiveSheet") "Range" "A1") "CurrentRegion")
     );setq
     (setq MaxRow# (vlax-get-property (vlax-get-property CurRegion "Rows") "Count"))
     (setq MaxColumn# (vlax-get-property (vlax-get-property CurRegion "Columns") "Count"))
   );progn
 );if
 (setq *ExcelData@ nil)
 (setq Row# 1)
 (repeat MaxRow#
   (setq Data@ nil)
   (setq Column# 1)
   (repeat MaxColumn#
     (setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
     (setq ExcelRange^ (vlax-get-property *ExcelApp% "Range" Range$))
     (setq ExcelVariant^ (vlax-get-property ExcelRange^ 'Value))
     (setq ExcelValue (vlax-variant-value ExcelVariant^))
     (setq ExcelValue
       (cond
         ((= (type ExcelValue) 'INT) (itoa ExcelValue))
         ((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
         ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
         ((/= (type ExcelValue) 'STR) "")
       );cond
     );setq
     (setq Data@ (append Data@ (list ExcelValue)))
     (setq Column# (1+ Column#))
   );repeat
   (setq *ExcelData@ (append *ExcelData@ (list Data@)))
   (setq Row# (1+ Row#))
 );repeat
 (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") 'Close :vlax-False)
 (vlax-invoke-method *ExcelApp% 'Quit)
 (setq *ExcelApp% nil)
 *ExcelData@
);defun GetExcel
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (GetCell "E19") = value of cell E19
(defun GetCell (Cell$ / Column# ColumnRow@ Return Row#)
 (setq ColumnRow@ (ColumnRow Cell$))
 (setq Column# (1- (nth 0 ColumnRow@)))
 (setq Row# (1- (nth 1 ColumnRow@)))
 (setq Return "")
 (if *ExcelData@
   (if (and (>= (length *ExcelData@) Row#)(>= (length (nth 0 *ExcelData@)) Column#))
     (setq Return (nth Column# (nth Row# *ExcelData@)))
   );if
 );if
 Return
);defun GetCell
; Arguments: 3
;   ExcelFile$ = Excel filename or nil for new spreadsheet
;   Visible = t for visible or nil for hidden
; Syntax examples:
; (OpenExcel "C:\\Temp\\Temp.xls" "Sheet2" t) = Opens C:\Temp\Temp.xls on Sheet2 as visible session
; (OpenExcel "C:\\Temp\\Temp.xls" nil nil) = Opens C:\Temp\Temp.xls on current sheet as hidden session
; (OpenExcel nil "Parts List" nil) =  Opens a new spreadsheet and creates a Part List sheet as hidden session
(defun OpenExcel (ExcelFile$ SheetName$ Visible / Sheet$ Sheets@ Worksheet)
   (if (findfile ExcelFile$)
     (setq *ExcelFile$ ExcelFile$)
       (exit)
     );progn
   );if
   (setq *ExcelFile$ "")
 );if
 (gc)
   );progn
 );if
 (if ExcelFile$
     (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Add)
   );if
 );if
 (if Visible
   (vla-put-visible *ExcelApp% :vlax-true)
 );if
 (if (= (type SheetName$) 'STR)
     (vlax-for Sheet$ (vlax-get-property *ExcelApp% "Sheets")
       (setq Sheets@ (append Sheets@ (list (vlax-get-property Sheet$ "Name"))))
     );vlax-for
     (if (member SheetName$ Sheets@)
         );if
       );vlax-for
       (vlax-put-property (vlax-invoke-method (vlax-get-property *ExcelApp% "Sheets") "Add") "Name" SheetName$)
     );if
   );progn
 );if
);defun OpenExcel
; Arguments: 2
;   StartCell$ = Starting Cell ID
;   Data@ = Value or list of values
; Syntax examples:
; (PutCell "A1" "PART NUMBER") = Puts PART NUMBER in cell A1
; (PutCell "B3" '("Dim" 7.5 "9.75")) = Starting with cell B3 put Dim, 7.5, and 9.75 across
(defun PutCell (StartCell$ Data@ / Cell$ Column# ExcelRange Row#)
 (if (= (type Data@) 'STR)
   (setq Data@ (list Data@))
 (setq ExcelRange (vlax-get-property *ExcelApp% "Cells"))
 (if (Cell-p StartCell$)
   (setq Column# (car (ColumnRow StartCell$))
         Row# (cadr (ColumnRow StartCell$))
   );setq
   (if (vl-catch-all-error-p
         (setq Cell$ (vl-catch-all-apply 'vlax-get-property
           (list (vlax-get-property *ExcelApp% "ActiveSheet") "Range" StartCell$))
         );setq
       );vl-catch-all-error-p
       (alert (strcat "The cell ID \"" StartCell$ "\" is invalid."))
       (setq Column# (vlax-get-property Cell$ "Column")
             Row# (vlax-get-property Cell$ "Row")
       );setq
   );if
 );if
 (if (and Column# Row#)
   (foreach Item Data@
     (vlax-put-property ExcelRange "Item" Row# Column# (vl-princ-to-string Item))
   );foreach
 );if
);defun PutCell
; CloseExcel - Closes Excel spreadsheet
; Arguments: 1
;   ExcelFile$ = Excel saveas filename or nil to close without saving
; Syntax examples:
; (CloseExcel "C:\\Temp\\Temp.xls") = Saveas C:\Temp\Temp.xls and close
; (CloseExcel nil) = Close without saving
(defun CloseExcel (ExcelFile$ / Saveas)
 (if ExcelFile$
   (if (= (strcase ExcelFile$) (strcase *ExcelFile$))
       (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") "Save")
       (setq Saveas t)
     );if
         (vl-file-delete (findfile ExcelFile$))
         (setq Saveas t)
       );progn
       (setq Saveas t)
     );if
   );if
 );if
 (if Saveas
     "SaveAs" ExcelFile$ -4143 "" "" :vlax-false :vlax-false nil
   );vlax-invoke-method
 );if
 (setq *ExcelApp% nil *ExcelFile$ nil)
);defun CloseExcel
; ColumnRow - Returns a list of the Column and Row number
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (ColumnRow "ABC987") = '(731 987)
(defun ColumnRow (Cell$ / Column$ Char$ Row#)
 (setq Column$ "")
 (while (< 64 (ascii (setq Char$ (strcase (substr Cell$ 1 1)))) 91)
   (setq Column$ (strcat Column$ Char$)
         Cell$ (substr Cell$ 2)
   );setq
 );while
 (if (and (/= Column$ "") (numberp (setq Row# (read Cell$))))
   (list (Alpha2Number Column$) Row#)
   '(1 1);default to "A1" if there's a problem
 );if
);defun ColumnRow
; Alpha2Number - Converts Alpha string into Number
; Arguments: 1
;   Str$ = String to convert
; Syntax example: (Alpha2Number "ABC") = 731
(defun Alpha2Number (Str$ / Num#)
 (if (= 0 (setq Num# (strlen Str$)))
   0
   (+ (* (- (ascii (strcase (substr Str$ 1 1))) 64) (expt 26 (1- Num#)))
      (Alpha2Number (substr Str$ 2))
 );if
);defun Alpha2Number
; Number2Alpha - Converts Number into Alpha string
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
 (if (< Num# 27)
   (chr (+ 64 Num#))
   (if (= 0 (setq Val# (rem Num# 26)))
     (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
     (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
   );if
 );if
);defun Number2Alpha
; Cell-p - Evaluates if the argument Cell$ is a valid cell ID
; Arguments: 1
;   Cell$ = String of the cell ID to evaluate
; Syntax examples: (Cell-p "B12") = t, (Cell-p "BT") = nil
(defun Cell-p (Cell$)
 (and (= (type Cell$) 'STR)
   (or (= (strcase Cell$) "A1")
     (not (equal (ColumnRow Cell$) '(1 1)))
   );or
 );and
);defun Cell-p
; Row+n - Returns the cell ID located a number of rows from cell
; Arguments: 2
;   Cell$ = Starting cell ID
;   Num# = Number of rows from cell
; Syntax examples: (Row+n "B12" 3) = "B15", (Row+n "B12" -3) = "B9"
(defun Row+n (Cell$ Num#)
 (setq Cell$ (ColumnRow Cell$))
 (strcat (Number2Alpha (car Cell$)) (itoa (max 1 (+ (cadr Cell$) Num#))))
);defun Row+n
; Column+n - Returns the cell ID located a number of columns from cell
; Arguments: 2
;   Num# = Number of columns from cell
; Syntax examples: (Column+n "B12" 3) = "E12", (Column+n "B12" -1) = "A12"
(defun Column+n (Cell$ Num#)
 (strcat (Number2Alpha (max 1 (+ (car Cell$) Num#))) (itoa (cadr Cell$)))
);defun Column+n
; rtosr - Used to change a real number into a short real number string
; stripping off all trailing 0's.
; Arguments: 1
;   RealNum~ = Real number to convert to a short string real number
; Returns: ShortReal$ the short string real number value of the real number.
(defun rtosr (RealNum~ / DimZin# ShortReal$)
 (setq DimZin# (getvar "DIMZIN"))
 (setvar "DIMZIN"
 (setq ShortReal$ (rtos RealNum~ 2 )
 (setvar "DIMZIN" DimZin#)
 ShortReal$
);defun rtosr
this should do it, type the formula in column C and copy down, (it uses a text height of 20, so change that to suit)
="-text "&B2&" 20 0 " & A2
