using acad 2010
i set a dynamic block with linear grips, now when i set the distance property the block always use absolute measure, sometimes i would like to use relative. how can i?
Thats not how dynamic blocks work. Dynamic parameters work from a base point and as such can only give the absolute value, if you wish to reinvent the wheel then it won't be a dynamic block and would probably be a lisp driven block or whatever you would like to call it. It isn't an available feature so maybe something you could develop???
im sure autodesk has it in the wishlist as its took for granted feature
Actually, it can be done. when you select a dynamic block with a stretch action and click on the grip the command line offers the option to use a base point, then pick a point on the end of the block move the mouse in the required direction and type a distance, you might need to try a couple of times but it actually works. It might not be exactly what you want but you can stretch a dynamic block with a given amount this way. Just make sure ortho is on because it will only use the x (or y) portion of the distance moved.
You learn something new here all the time :>)
Edited by steven-g
