katto01
VBA - information on selection
katto01
Hello,
Q1: How do I get the number of entities in a selection using VBA?
Q2: What is the command/method to find the type of each entity in a selection using VBA?
Thank you
Share this post
Link to post
RICVBA
A1: use .Count method of SelectionSet object
A2: you could use typeOf() like:
If typeOf acEnt Is AcadLine then
and the likes where acEnt is some AcadEntity type variable you're looping through SelectionSet with
Share this post
Link to post
Grrr
Heres my example-attempt:
Sub test() 'define a named function
 'Filter for circles - I don't know how to implement this type of filtering:
 'Dim gpCode(0) As Integer
 'Dim dataValue(0) As Variant
 'gpCode(0) = 0
 'dataValue(0) = "Circle"
 Dim SS As AcadSelectionSet 'Declare "SS" variable as local
 Set SS = ThisDrawing.SelectionSets.Add("NewSS") 'create a new selection set object [include it in the "SelectionSets" collection]
 SS.SelectOnScreen 'select the objects to change (invoke the "SelectOnScreen" method)
 For Each Entity In SS 'iterate over the selection set
   If Entity.ObjectName = "AcDbCircle" Then 'Filter for circles by objectname
     Entity.color = 1 'change entity's colour
   End If
 Next 'process the next entity
 MsgBox SS.Count 'alert the total selected amount of objects
 SS.Delete 'delete the selection set object [exclude it from the "SelectionSets" collection]
End Sub
I'm just starting to learn about VBA, so any inputs are appreciated.
Share this post
Link to post
BIGAL
Grr this may be usefull
Dim FilterDXFCode(0) As Integer
Dim FilterDXFVal(0) As Variant
FilterDXFCode(0) = 0
FilterDXFVal(0) = "INSERT"
'FilterDXFCode(1) = 2
'FilterDXFVal(1) = "SCHEDTEXT"
Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
for circle
FilterDXFVal(0) = "CIRCLE"
lisp (0 . "Insert")
Share this post
Link to post
Grrr
Thanks BIGAL!
This second shot worked:
 'SS.Select acSelectionSetWindow , , , FilterDXFCode, FilterDXFVal '<<< BIGAL's example
 SS.SelectOnScreen FilterDXFCode, FilterDXFVal 'select the objects to change (invoke the "SelectOnScreen" method) and include filters
End Sub
It seems hard for me to get use with VBA, from lisp (since the lack of syntaxes).
First Impressions are that VBA and Visual Lisp (not Vanilla) are related, you have to, create a Selection Set Object, invoke a method and iterate thru it - instead of a single ssget function, that would be enough in vanilla lisp (altho still requires iteration).
With Visual Lisp it would wook like this:
 (lambda ( / SS )
   (vla-SelectOnScreen
     (setq SS (vla-Add (vla-get-SelectionSets (vla-get-ActiveDocument (vlax-get-acad-object))) "NewSS"))
     (vlax-safearray-fill (vlax-make-safearray vlax-vbinteger '(0 . 0)) '(0))
     (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 0)) '("CIRCLE"))
   (vlax-for o SS (vla-put-Color o 1))
   (vla-Delete SS)
P.S. Sorry for late reply - I'm busy with other kind of work (computerless).
Share this post
Link to post
