Hi,
I have inserted an OLE Jpeg into my drawing. It displays properly in AutoCAD, and even in the print preview, but when I print to PDF it dissapears.
Any ideas? I've tried changing it's 'plot quality' to low. I've also tried two PDF writters.
The same dwg will print to PDF fine in Microstation, so I don't think there's anything wrong with the jpeg :?
Thanks
how did you insert it? In the past I've had hit and miss with images in autocad/pdf, sometimes I drag the file to the drawing, and other times I copy and paste it from paint. Also, there's "imageframe" try changing the settings between 0, 1, & 2 and see how it goes.
Thank you kari_sinkko, I'll try that!
Mr. Alex, I've had that same problem too, if Kari_sinkko's suggestion
doesn't work, then the "workaround" I have to do is deletethe image
out of the drawing and then re-insert it, that sorts it out for me.
