Rain0923 Posted August 25, 2017 Posted August 25, 2017 I found a lisp from Tharwat and as below Web(It is good) Have any way let block quickly and it don't need to select point? There are 1000 texts need to create block. ; Quick Block ; Creates a block instantly out of the objects that you select ; Found at [url]http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Quick-block/td-p/3454228[/url] (defun c:QB (/ selectionset insertionpoint number Blockname) ;;; Tharwat 11. May. 2012 ;; (if (and (setq selectionset (ssget "_:L")) (setq insertionpoint (getpoint "\n Specify insertion point :")) ) (progn (setq number 1 Blockname (strcat "MyBlock" (itoa number)) ) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat "MyBlock" (itoa (setq number (1+ number)))) ) ) (command "_.-Block" Blockname insertionpoint selectionset "") (command "_.-insert" Blockname insertionpoint "" "" "") ) (princ) ) (princ) ) Quote
StevJ Posted August 25, 2017 Posted August 25, 2017 Here's one I use. It doesn't require an insertion point, but it makes anonymous blocks, which may not be what you want because they do not show in Autocad's Block Editor. Steve ;;; MAKES ANONYMOUS BLOCKS ;;; (princ "\n This code is provided Unscramnbled - for free - given that it is not altered") (princ "\n Thanks for your understanding, www.xordesign.com ") (princ "\n Type TBLOCK to start ") (defun c:TBLOCK (/ sset tell ent ent_get entu ent_getu blk) (princ "\n Select objects to group into anonymous Block: ") (setq sset (ssget)) (if sset (progn (entmake (list '(0 . "BLOCK") '(2 . "*U") '(70 . 1) '(10 0.0 0.0 0.0))) (setq tell 0) (setq ent (ssname sset tell)) (while ent (setq ent_get (entget ent)) (if (/= (cdr (assoc 0 ent_get)) "POLYLINE") (progn (setq ent_getu (cdr ent_get)) (entdel ent) (entmake ent_getu)) (progn (setq entu ent ent_getu (cdr ent_get)) (while (/= (cdr (assoc 0 ent_getu)) "SEQEND") (setq ent_getu (cdr (entget entu))) (entmake ent_getu) (setq entu (entnext entu)) );while (entdel ent) ) );if (setq tell (+ tell 1)) (setq ent (ssname sset tell)) ) (setq blk (entmake (list '(0 . "ENDBLK")))) (entmake (list '(0 . "INSERT") (cons 2 blk) '(10 0.0 0.0 0.0))) );progn );if (princ "\n Anonymous block created. Explode to ungroup") (princ) ) (princ) Quote
Rain0923 Posted August 25, 2017 Author Posted August 25, 2017 Hi Steve Thanks For 1000 texts Can it have 1000 points?The pionts set on every text centor. Here's one I use. It doesn't require an insertion point, but it makes anonymous blocks, which may not be what you want because they do not show in Autocad's Block Editor. Steve ;;; MAKES ANONYMOUS BLOCKS ;;; (princ "\n This code is provided Unscramnbled - for free - given that it is not altered") (princ "\n Thanks for your understanding, www.xordesign.com ") (princ "\n Type TBLOCK to start ") (defun c:TBLOCK (/ sset tell ent ent_get entu ent_getu blk) (princ "\n Select objects to group into anonymous Block: ") (setq sset (ssget)) (if sset (progn (entmake (list '(0 . "BLOCK") '(2 . "*U") '(70 . 1) '(10 0.0 0.0 0.0))) (setq tell 0) (setq ent (ssname sset tell)) (while ent (setq ent_get (entget ent)) (if (/= (cdr (assoc 0 ent_get)) "POLYLINE") (progn (setq ent_getu (cdr ent_get)) (entdel ent) (entmake ent_getu)) (progn (setq entu ent ent_getu (cdr ent_get)) (while (/= (cdr (assoc 0 ent_getu)) "SEQEND") (setq ent_getu (cdr (entget entu))) (entmake ent_getu) (setq entu (entnext entu)) );while (entdel ent) ) );if (setq tell (+ tell 1)) (setq ent (ssname sset tell)) ) (setq blk (entmake (list '(0 . "ENDBLK")))) (entmake (list '(0 . "INSERT") (cons 2 blk) '(10 0.0 0.0 0.0))) );progn );if (princ "\n Anonymous block created. Explode to ungroup") (princ) ) (princ) Quote
maratovich Posted August 25, 2017 Posted August 25, 2017 Rain0923 See attachment, this is a program, not a lisp. Unzip the archive, open dwg file, start program, click Start. TextToBlock.zip Quote
StevJ Posted August 26, 2017 Posted August 26, 2017 Rain0923, My understanding was that you wanted to make a single block consisting of all texts in your drawing. If your objective is to turn each line of text in a drawing into its own separate block, the TBLOCK program I suggested is not the tool for that job. Steve Quote
Rain0923 Posted August 30, 2017 Author Posted August 30, 2017 Thank you for your help,but this program can't download in my company. Still thank you!! Rain0923See attachment, this is a program, not a lisp. Unzip the archive, open dwg file, start program, click Start. Quote
Rain0923 Posted August 30, 2017 Author Posted August 30, 2017 Still thank you!!thank you!! Rain0923,My understanding was that you wanted to make a single block consisting of all texts in your drawing. If your objective is to turn each line of text in a drawing into its own separate block, the TBLOCK program I suggested is not the tool for that job. Steve Quote
maratovich Posted August 30, 2017 Posted August 30, 2017 Thank you for your help,but this program can't download in my company.Still thank you!! Why? Did you watch it? It does not need to be installed. Quote
Rain0923 Posted August 30, 2017 Author Posted August 30, 2017 Yes watched it at home. But I just can download file(EX:pdf, doc, xls, ppt, txt) For exe file,I can't download in my company. Thank you very much Thank you very much Thank you very much Why?Did you watch it? It does not need to be installed. Quote
Rain0923 Posted August 31, 2017 Author Posted August 31, 2017 If I could Iwill but my computer doesn't USB port.:cry: Thank you!! Flash drive Quote
Rain0923 Posted November 14, 2017 Author Posted November 14, 2017 Flash drive Hello maratovich I tried your program,it's good for me. thank you very much. By the way, one more question can it create name base on number? example the text is 1 then blockname is 1 & the text is 2 then blockname is 2....... Quote
maratovich Posted November 14, 2017 Posted November 14, 2017 I do not understand everything. Attach an example of how it should be. Quote
Rain0923 Posted November 15, 2017 Author Posted November 15, 2017 I do not understand everything.Attach an example of how it should be. Pls try on file.....thanksexample.dwg Quote
maratovich Posted November 17, 2017 Posted November 17, 2017 I'm very busy right now. I'll check in a week. Quote
Jef! Posted November 17, 2017 Posted November 17, 2017 Try this one (defun c:QB2 ( / ss idx inspnt number Blockname itmss itm) ;inspired by Quick block from Tharwat (11. May. 2012) ;modified to automatically make block from texts in the current layout ;by Jef! on 2017-11-17 (command "._undo" "_be") (if (setq ss (ssget "_X" (list '(0 . "TEXT") (cons 410 (getvar 'ctab))))) (progn (setq number 1 Blockname (strcat "MyBlock" (itoa number)) itmss (ssadd) ) (repeat (setq idx (sslength ss)) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat "MyBlock" (itoa (setq number (1+ number))))) ) (setq inspnt (cdr(assoc 10 (entget (setq itm (ssname ss (setq idx (1- idx))))))) itmss (ssadd itm) ) (vl-cmdf "_.-Block" Blockname inspnt itmss "") (vl-cmdf "_.-insert" Blockname inspnt "" "" "") ) ) ) (command "._undo" "_e") (princ) ) You owe 1 beer to Tharwat and 1 beer to me each time you execute it. Deal? Cheers! Quote
Rain0923 Posted November 21, 2017 Author Posted November 21, 2017 Try this one (defun c:QB2 ( / ss idx inspnt number Blockname itmss itm) ;inspired by Quick block from Tharwat (11. May. 2012) ;modified to automatically make block from texts in the current layout ;by Jef! on 2017-11-17 (command "._undo" "_be") (if (setq ss (ssget "_X" (list '(0 . "TEXT") (cons 410 (getvar 'ctab))))) (progn (setq number 1 Blockname (strcat "MyBlock" (itoa number)) itmss (ssadd) ) (repeat (setq idx (sslength ss)) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat "MyBlock" (itoa (setq number (1+ number))))) ) (setq inspnt (cdr(assoc 10 (entget (setq itm (ssname ss (setq idx (1- idx))))))) itmss (ssadd itm) ) (vl-cmdf "_.-Block" Blockname inspnt itmss "") (vl-cmdf "_.-insert" Blockname inspnt "" "" "") ) ) ) (command "._undo" "_e") (princ) ) You owe 1 beer to Tharwat and 1 beer to me each time you execute it. Deal? Cheers! Cheers!!It is very good for me,I owe you and Tharwat.Thanks a lot!! Quote
muhsinos Posted April 14, 2018 Posted April 14, 2018 Tharwat script is excelent, but need a little help.. Instead of auto naming, is it possible to select a text or mtext as the block name after specifying the insertion point? Any help would be appreciated.... Thanks Quote
