BIGAL Posted August 30, 2017 Posted August 30, 2017 This explains all the settings and theer is lots with dims but look at dxf code 60 https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/qleader-variables-in-lisp-routine/td-p/4801171 Scoll down for code answer. Qlset_v1.lsp Quote
wimal Posted August 31, 2017 Author Posted August 31, 2017 This explains all the settings and theer is lots with dims but look at dxf code 60https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/qleader-variables-in-lisp-routine/td-p/4801171 Scoll down for code answer. Qlset_v1.lsp Thanks a lot I got the idea from that program. Quote
wimal Posted September 2, 2017 Author Posted September 2, 2017 (entmod (subst (cons 60 [color="red"][b]4[/b][/color])(assoc 60 (Setq xr(dictsearch (namedobjdict) "acaddim")))xr)) Why cant I replace new value with this code to set leader annotation to None Quote
Tharwat Posted September 2, 2017 Posted September 2, 2017 (entmod (subst (cons 60 [color="red"][b]4[/b][/color])(assoc 60 (Setq xr(dictsearch (namedobjdict) "acaddim")))xr)) Why cant I replace new value with this code to set leader annotation to None https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/qleader-variables-in-lisp-routine/m-p/5446515/highlight/true#M328413 Quote
wimal Posted September 3, 2017 Author Posted September 3, 2017 (edited) Thanks Mr.Tharwat. Finally I got it. Edited September 3, 2017 by wimal Quote
Tharwat Posted September 3, 2017 Posted September 3, 2017 Thanks Mr.Tharwat. Finally I got it. You are welcome. Thanks to Henrique for giving that example. Quote
wimal Posted September 3, 2017 Author Posted September 3, 2017 You are welcome. Thanks to Henrique for giving that example. Yes Thanks Mr. Henrique for giving that example. Quote
