designerstuart Posted July 17, 2012 Share Posted July 17, 2012 hi all did anyone alter this code to allow selection of specific blocks? ps. i am partly answering as when i click 'page2' i get a 404 forbidden error Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 17, 2012 Share Posted July 17, 2012 ps. i am partly answering as when i click 'page2' i get a 404 forbidden error The issue is from the title of this thread, more precisely the "..." parts; this cause conflicts (at least) with IE browser. To fix it just go to address bar and remove the title part and press : http://www.cadtutor.net/forum/showthread.php?13295-Looking-for-a-Lisp-routine..../page2 Hope that a moderator will fix this. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 17, 2012 Share Posted July 17, 2012 Should be fixed now. You can always set to display more threads per page in your settings. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted July 17, 2012 Share Posted July 17, 2012 You can always set to display more threads per page in your settings. ooooh will do thanks. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted July 17, 2012 Share Posted July 17, 2012 still looking for the lisp that changes specific blocks' entities to layer0 though! Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 17, 2012 Author Share Posted July 17, 2012 still looking for the lisp that changes specific blocks' entities to layer0 though!Since this thread, Autodesk incorporated the SETBYLAYER command which was not available when I was looking for this original LISP routine. Try this instead, it works really well. More info: http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c875431154102.htm Quote Link to comment Share on other sites More sharing options...
irneb Posted July 18, 2012 Share Posted July 18, 2012 still looking for the lisp that changes specific blocks' entities to layer0 though!Like this?(defun c:BlkToLay0 (/ ss n eo bLst bCol) (vl-load-com) (if (setq ss (ssget '((0 . "INSERT")))) (progn (repeat (setq n (sslength ss)) (setq eo (vlax-ename->vla-object (ssname ss (setq n (1- n))))) (if (not (vl-position (vla-get-EffectiveName eo) bLst)) (setq bLst (cons (vla-get-EffectiveName eo) bLst)))) (setq bCol (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) (foreach bName bLst (setq eo (vla-Item bCol bName)) (vlax-for obj eo (vl-catch-all-apply 'vla-put-Layer (list obj "0")))))) (princ)) Quote Link to comment Share on other sites More sharing options...
designerstuart Posted July 18, 2012 Share Posted July 18, 2012 styk - that's great for setting objects 'by layer', but doesn't go the whole hog and put them on layer0. irneb - i'm maybe doing sth wrong, but your code did nothing for me! thanks all Quote Link to comment Share on other sites More sharing options...
designerstuart Posted July 18, 2012 Share Posted July 18, 2012 i'm looking to alter a bit of the former script's code so the default is my prefered choice: (initget "byLayer byBlock") (setq atype (getkword "\nSet block contents to [byLayer/byBlock] <[color=red]byBlock[/color]>:")) (initget "Yes No") (setq ans0 (getkword "\nChange entity layers to layer0? [Yes/No] <[color=red]No[/color]>:")) i want and instead. obviously i can change the words, but can someone pls tell me what bit of the code i need to alter to make it work? thanks chaps Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 18, 2012 Share Posted July 18, 2012 Here is an old function of mine which may help: http://lee-mac.com/applytoblockobjects.html Quote Link to comment Share on other sites More sharing options...
designerstuart Posted July 18, 2012 Share Posted July 18, 2012 okay thanks lee. should have known to look on your site first! i don't understand the first bit - but have taken the test bit, which ofc works brill like. ta still interested to learn about how to alter the code above if it's easy! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 18, 2012 Share Posted July 18, 2012 okay thanks lee. should have known to look on your site first!i don't understand the first bit - but have taken the test bit, which ofc works brill like. ta still interested to learn about how to alter the code above if it's easy! You're welcome designerstuart. Note that you needn't modify the LM:ApplytoBlockObjects function, since this is simply a wrapper function that allows you to operate on the subentities within a block definition. The example program calls this function with the block collection, the block name and a function to be applied to every object within the block definition. In the example, this function merely changes the layer of every object to layer "0". Quote Link to comment Share on other sites More sharing options...
irneb Posted July 18, 2012 Share Posted July 18, 2012 irneb - i'm maybe doing sth wrong, but your code did nothing for me!Could you provide a sample DWG where my code does not change the entities inside the block to layer 0? If I run it it works perfectly for me. Note, that's all it does - it leaves colour / linetype / etc. as is (though these could be added as well). Or did I read your post wrong? Did you mean you want to set only certain objects inside the block to Layer 0? The principle behind my code is much the same as Lee's code (aslo VVA's in post #6), though mine simply finds all blocknames from the selection then loops through each name. Lee's is a bit more of a "functional" approach, whereas VVA's & mine is more of an "imperative" approach. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 18, 2012 Share Posted July 18, 2012 I see nothing wrong with your code Irne - perhaps designerstuart didn't do a regen to update the references. Quote Link to comment Share on other sites More sharing options...
irneb Posted July 18, 2012 Share Posted July 18, 2012 I see nothing wrong with your code Irne - perhaps designerstuart didn't do a regen to update the references. That's why I've asked for a sample DWG. I'd like to know where my code won't work, if such exists I'd like to learn about it. You might be correct about the regen - it seems to be the most plausible reason. Thanks for checking though Quote Link to comment Share on other sites More sharing options...
dober Posted July 18, 2012 Share Posted July 18, 2012 Hello How would that go if everything is on layer 0 only the hatching remain as it is. Thank you Hallo Wie würde das gehn wenn alles auf Layer 0 nur die Schraffur soll bleiben wie sie ist. Danke Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 18, 2012 Share Posted July 18, 2012 Hi dober, To exclude Hatch Objects from the layer change, use the following program with my LM:ApplytoBlockObjects function: (defun c:test ( / s ) (if (setq s (LM:ssget "\nSelect Block: " '("_+.:E:S" ((0 . "INSERT"))))) (LM:ApplytoBlockObjects (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (ssname s 0)))) '(lambda ( obj ) (if (not (eq "AcDbHatch" (vla-get-objectname obj))) (vla-put-layer obj "0") ) ) ) ) (princ) ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; ;; Arguments: ;; msg - selection prompt ;; params - list of ssget arguments (defun LM:ssget ( msg params / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget params)) (setvar 'nomutt 0) (if (and sel (not (vl-catch-all-error-p sel))) sel ) ) Remember to Regen to see the changes. Quote Link to comment Share on other sites More sharing options...
dober Posted July 18, 2012 Share Posted July 18, 2012 (edited) Thank you Lee has been running Danke Lee läuft schon Edited July 18, 2012 by dober Quote Link to comment Share on other sites More sharing options...
