lkrkck Posted September 12, 2017 Posted September 12, 2017 Hello, I've this code to move some AcadPoints tPerpendicular of one 2DPolyline. The problem: I've this points with Z value, when i run the code this points goes perpendicular to line but with Z=0. (defun c:SnapToObj ( / en obj pts_ss ss_len c pten ptobj pted pt pt2) (setq en (car (entsel "\nSelect Object: "))) (setq obj (vlax-ename->vla-object en)) (princ "\nSelect points: ") (setq pts_ss (ssget (list (cons 0 "POINT")))) (setq ss_len (sslength pts_ss)) (setq c 0) (while (< c ss_len) (setq pten (ssname pts_ss c)) (setq ptobj (vlax-ename->vla-object pten)) (setq pted (entget pten)) (setq pt (cdr (assoc 10 pted))) (setq pt2 (vlax-curve-getClosestPointTo obj pt)) (vla-move ptobj (vlax-3d-point pt) (vlax-3d-point pt2)) (setq c (+ c 1)) ) (princ) ) Quote
