Necesito enviar todos las circunferencias a la coordenada z = 0.
Esto para poder encontrar las interferencias entre los circunferencias mostradas.
Alguien que pueda ayudarme, de ya muchas gracias.
Como adjunto el archivo. Ya utilicé la herramienta flatten, pero aparentemente las circunferencias no tienen la coordenada z = 0.PROCESAMIENTO REV D.dwg
use Filter "Circle" then properties set Z 0.0
Or lisp
2 respuestas
utilice Filtro "Círculo" luego las propiedades establecidas Z 0.0
O lisp
(defun circ0 ( / ss x obj cen pt)
(setq ss (ssget "x" (list (cons 0 "Circle"))))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq cen (vlax-safearray->list (vlax-variant-value (vla-get-center obj))))
(setq pt (list (car cen) (cadr cen) 0.0))
(vla-put-center obj (vlax-3d-point pt))
(circ0)
Excelent, Thank you very much.
Now,how can I get the interference count between all elements, circles, ellipses, etc.
The plane in dwg is in the first comentary. Please download.
Not very fast, but give this a try:
(defun c:foo (/ i i2 o p s)
 (if
   (and
     (setq s (ssget "_x" '((0 . "circle,ellipse") (410 . "Model"))))
     ;; Convert selset to list of vla objects
     (setq s (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex s))))
     ;; Put all centers z's @ 0.0
     (mapcar
'(lambda (x) (setq p (vlax-get x 'center)) (vlax-put x 'center (list (car p) (cadr p) 0.0)))
s
     (setq i 0)
    (while (setq o (car s))
      (setq s (cdr s))
      ;; Check for intersections
      (if (setq tmp (vl-remove-if-not
	       (function (lambda (x)
			   (if (setq i2 (vlax-invoke o 'intersectwith x acextendnone))
			     (setq i (+ i (length i2)))
	       s
 ;; Make objects green
 (mapcar '(lambda (x) (vla-put-color x 3)) (append tmp (list o)))
 (print (strcat (vl-princ-to-string (/ i 3.)) " intersections..."))
(vl-load-com)
And if we only want to find the number of intersections for a group of selected elements.
Try this:
 (if
   (and
     (setq s (ssget ":L" '((0 . "circle,ellipse") (410 . "Model"))))
     (setq s (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))
     (mapcar
s
     (setq i 0)
      (setq s (cdr s))
	       s
(vl-load-com)
  • 6 months later...
Estimado Ronjonp, y para enviar a todos los dibujos a la cota z = 0 sin usar flatten ?
So if I translated your message correctly, THIS should be what you're looking for.
