rgarjr Posted January 15, 2009 Posted January 15, 2009 Sometimes when a dialog box pops up it will blackout some of my viewports, then if I move it or close the dialog box it returns to normal. Quote
ReMark Posted January 15, 2009 Posted January 15, 2009 At least it "returns to normal". You're computer specs are borderline for RAM. Not sure if that is part of the problem. Are you working in 2D or 3D? How many viewports do you have showing? Quote
Cad64 Posted January 15, 2009 Posted January 15, 2009 Is this an Autocad question or 3DS Max? Does this happen in every file or just one? Quote
rgarjr Posted January 15, 2009 Author Posted January 15, 2009 Its on Max 09. I'm thinking its maybe a configuration thing, yeah it does it just about any time a dialog box pops up. Quote
ReMark Posted January 15, 2009 Posted January 15, 2009 When did the problem first occur? Has it always been this way? Have all service packs been applied? Quote
Cad64 Posted January 16, 2009 Posted January 16, 2009 So it could be any dialog at any time that causes this? Not any particular dialog while you're performing a specific action? Or only on large complex files? Or only when you have other applications open? It could just be your video card. The 1600 series ATI cards are commonly referred to as "budget" cards. The X1650 is the best of ATI's low end cards, but you should probably look into upgrading. That's really the only thing that I can think of. I've never experienced a problem like this? Quote
rgarjr Posted January 16, 2009 Author Posted January 16, 2009 Yah its always been like that and I have the latest service packs. Having a dialog box opened and moving it above a vp will do it, also when changing from wire to shaded. Its no biggie though since it goes right back to normal right away after panning. Well it turns out, its because I'm running dual monitors and had Max on the right side one. Having it on the left (primary) does not do it. . Quote
