Lisp required to make text rotated to 0 angle & make changes in font style & height
Hi Lisp Legends,
i need a help in creating a lisp, actually i have drawing with lot (nearly thousands of text to converted in a single drawing file) of text to be converted from different angles to zero angle & also to change its text height & font style as shown in attached .dwg file,
Another important thing is i need to remove the / symbol from that text & re-arrange as shown in the attached .dwg file.
Kindly look on this & requesting to please provide lisp for this work.
TEXT CONVERTION.dwg
Everything you want has been done before, using vlisp it is a simple task to use a PUT to change a text value eg (vla-put-Rotation txtobject 0.0) same with text style. Or use the entity dxf codes and entmod.
ObjectName (RO) = "AcDbMText"
; OwnerID (RO) = 43
; PlotStyleName = "ByLayer"
; Rotation = 0.504313
; StyleName = "dgnlstyle-lstyle"
; TextString = "P50/450D6 GEL/FUSION 1439"
these are in a suggested order.
1 There is lots of examples regarding search and replace the easiest is from command line FIND P50/ Replace with nothing.
2 The text to mtext again a bit of a quick search should find.
3 The / to new line was solved say last week here at cadtutor.
4 Change angle and style.
; OwnerID (RO) = 43
Hi Bigal,
Thanks for your reply, actually i am not aware of VLSIP, could you please help me on how to save your code & use it.
