trefan123 Posted September 26, 2017 Posted September 26, 2017 Good Day, Please can you help my first post ....not to good in this field.. When changing on of the user inputs (userr*) insted of defaulting back to the input screen i get the argument error. What im looking for is once the user input is changed it revises the userr* and returns to the default list.. only exit (5) will clear Lisp (defun C:isovars () (if (= (getvar "USERR1") 0) (setvar "USERR1" 1)) (if (= (getvar "USERR2") 0) (setvar "USERR2" 2)) (if (= (getvar "USERR3") 0) (setvar "USERR3" 3)) (terpri) (terpri) (textscr) (princ) (prompt "\n SYSTEM VARIABLES FOR THIS DRAWING SESSION ") (prompt "\n-------------------------------------------") (terpri) (terpri) ; (prompt "\n1. VALVE, ELBOW AND REDUCER SCALE FACTOR") (terpri) (setq v1 (getvar "userr1")) (prompt (strcat " (i.e. Scale Factor of 1 = 20mm Fitting Size Weld to Weld (Valve)) " ": ")) (terpri) ; (prompt "\n2. INSTRUMENTATION / SYMBOL SIZES") (terpri) (setq v2 (getvar "userr2")) (prompt (strcat " (i.e. Scale Factor of 1 = 15mm Symbol Size) " ": ")) (terpri) ; (setq v3 (getvar "userr3")) (prompt (strcat "\n3. CIRCLE RADIUS (Bubbles) " " : ")) (terpri) ; (terpri) (setq v4 (getvar "textsize")) (prompt (strcat "4. TEXT SIZE " ": ")) (terpri) ; (terpri) (prompt "5. EXIT - RETURN TO DRAWING ") (terpri) (terpri) ; (initget "1 2 3 4 5") (setq sel (getkword "\nEnter Selection: ")) (if (= sel "1") (progn (initget +1 2 4) (setq valvar (getreal "\nENTER NEW VALVE, ELBOW AND REDUCER SCALE FACTOR: ")) (setvar "userr1" valvar) (princ) (isovars) )) (if (= sel "2") (progn (initget (+ 1 2 4)) (setq nozvar (getreal "\nENTER NEW INSTRUMENTATION / SYMBOL SCALE FACTOR: ")) (setvar "userr2" nozvar) (princ) (isovars) )) (if (= sel "3") (progn (initget (+ 1 2 4)) (setq circlevar (getreal "\nENTER NEW CIRCLE RADIUS: ")) (setvar "userr3" circlevar) (princ) (isovars) )) (if (= sel "4") (progn (initget (+ 1 2 4)) (setq textvar (getreal "\nENTER NEW TEXT SIZE: ")) (setvar "textsize" textvar) (princ) (isovars) )) (if (= sel "5") (progn (graphscr) (command nil) )) ) Thanks Quote
trefan123 Posted September 26, 2017 Author Posted September 26, 2017 Good Day,Please can you help my first post ....not to good in this field.. When changing on of the user inputs (userr*) insted of defaulting back to the input screen i get the argument error. What im looking for is once the user input is changed it revises the userr* and returns to the default list.. only exit (5) will clear Lisp (defun C:isovars () (if (= (getvar "USERR1") 0) (setvar "USERR1" 1)) (if (= (getvar "USERR2") 0) (setvar "USERR2" 2)) (if (= (getvar "USERR3") 0) (setvar "USERR3" 3)) (terpri) (terpri) (textscr) (princ) (prompt "\n SYSTEM VARIABLES FOR THIS DRAWING SESSION ") (prompt "\n-------------------------------------------") (terpri) (terpri) ; (prompt "\n1. VALVE, ELBOW AND REDUCER SCALE FACTOR") (terpri) (setq v1 (getvar "userr1")) (prompt (strcat " (i.e. Scale Factor of 1 = 20mm Fitting Size Weld to Weld (Valve)) " ": ")) (terpri) ; (prompt "\n2. INSTRUMENTATION / SYMBOL SIZES") (terpri) (setq v2 (getvar "userr2")) (prompt (strcat " (i.e. Scale Factor of 1 = 15mm Symbol Size) " ": ")) (terpri) ; (setq v3 (getvar "userr3")) (prompt (strcat "\n3. CIRCLE RADIUS (Bubbles) " " : ")) (terpri) ; (terpri) (setq v4 (getvar "textsize")) (prompt (strcat "4. TEXT SIZE " ": ")) (terpri) ; (terpri) (prompt "5. EXIT - RETURN TO DRAWING ") (terpri) (terpri) ; (initget "1 2 3 4 5") (setq sel (getkword "\nEnter Selection: ")) (if (= sel "1") (progn (initget +1 2 4) (setq valvar (getreal "\nENTER NEW VALVE, ELBOW AND REDUCER SCALE FACTOR: ")) (setvar "userr1" valvar) (princ) (isovars) )) (if (= sel "2") (progn (initget (+ 1 2 4)) (setq nozvar (getreal "\nENTER NEW INSTRUMENTATION / SYMBOL SCALE FACTOR: ")) (setvar "userr2" nozvar) (princ) (isovars) )) (if (= sel "3") (progn (initget (+ 1 2 4)) (setq circlevar (getreal "\nENTER NEW CIRCLE RADIUS: ")) (setvar "userr3" circlevar) (princ) (isovars) )) (if (= sel "4") (progn (initget (+ 1 2 4)) (setq textvar (getreal "\nENTER NEW TEXT SIZE: ")) (setvar "textsize" textvar) (princ) (isovars) )) (if (= sel "5") (progn (graphscr) (command nil) )) ) Thanks (isovars) replaced with (c:isovars) still error Quote
