ankurpraja Posted September 27, 2017 Posted September 27, 2017 Adaptive Gusset.ipt Hi All, Attached is the adaptive part i made in Inventor 2018. This is used for I-Beams and Channels. There are no constrains in the sketch so that when i constrain the part in the assembly, it will adapt the size of that beam. This all works fine except that the sketch will not remain at the origin. I would like to use the origin planes to constrain for other occurrences in the assembly. And if i constrain the sketch to the origin then the part will not be adaptive in the assembly. Any solution for above? I don't want to add new planes. Thanks. Quote
