Dear all.
This is something I tried years ago, without success; let's try again with you wise men (and women): we have many routines which iterate the full database drawing many times, so not to fulfill the console screen (you know, the F2 one ;) with text, we print on it a single variable character as a feedback for the user as everything is up and running, despite the long time usually taken by these routines.
Problem rely in the console's character buffer, as every (princ "[char]") IS NOT visualized till the buffer fills, so appearing sudden chunks of characters after long silence lapses, or when the routine ends.
I've tried (prin? ..) (prompt ..) and (write-char ..) without success. Ideas?
By the way, would be nice to find a solution pre-VisualLisp compatible (but not mandatory ;)
Regards
While iteration you could use (acet-ui-progress*) functions to visualize processing of iterations - you have to implement those functions inside your lisp(s)... Try google-ing for "ACET-UI-PROGRESS" to get more info how to do it...
Thanks a lot; it looks like de PRO option, but I promise to try to implement it...
Nevertheless, would be nice to find something like (flush-what-ever ..) that could be added to our old routines effort-less... :)
I think I understand.
I use this for a visual progress display since A2K ( this is when visual was incorporated into autolisp whether you wanted it or not )
[b][color=BLACK]([/color][/b]defun c:vprog [b][color=FUCHSIA]([/color][/b]/ ss i en ed la[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b]
      [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]princ [color=#2f4f4f]"\t\t\r"[/color][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]prin1 en[b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b]
                   la [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Sometimes a (princ) was required as the else statement in order to display.
This can be modified to work with tables as well
-David
I would go the same way as Marko, you can make it a defun so call it for multiple steps, we have something that does 5 steps so useful to see that something is happening.
; This is example code
(setq  doc (vla-get-activedocument (vlax-get-acad-object))) ; open database
(setq allblocks (vla-get-blocks doc)) ; get all the blocks in dwg
(setq numinc (/ 100.0 (vla-get-count allblocks))) ; divide num of blocks as ratio of 100%
(setq num 0.0)
(acet-ui-progress-init "Block to bylayer" 100); heading - interval length heading could  be a variable
(vlax-for block allblocks
(acet-ui-progress-safe (setq num (+ num numinc))); update progressbar
(command "delay" "100") ; dummy line as progress bar will just flash remove if doing lots of stuff
) ;_ end of vlax-for
(acet-ui-progress-done); dismiss progressbar
(command "regen") ; remove progress bar
